Hi, is there a possibility to create new surface based on others two existing.
I mean with exactly the same effect as on the picture.
Picture below presents example profiles of terrain (cyan) and rock surfaces (red) and the green one is that one I want to build - it is updated rock surface.
There is simple rule, in every place where rock surface crossing EG it should take elevation from the EG (= it never takes elevations above EG).
I hope it is clear, if not I will try to precise describe.
Regars, Chris
