Author Topic: Block Attributes - order in property pallet  (Read 1984 times)
DIW_CADtech
  • Push limits, embrace success, & discard failure.
« on: September 16, 2015, 05:44:08 PM »
How do you set the order of the attributes in the properties pallet.
I just created a terminal block with 48 terminals and a ATTDEF for the left color and number description and right color and number, and when i create the block, all the atributes are in the opposite order in the properties pallet.  Any idea how to set the order?
I created the block from the top down,, If I have to start over I may have to shoot myself.
I am very  trainable....   (forgive my spelling)
Jeff H
Re: Block Attributes - order in property pallet
« Reply #1 on: September 16, 2015, 06:08:04 PM »
Whatever you do, do not open block in block editor and run BATTORDER command and reorder the attributes how you want them.
« Reply #2 on: September 16, 2015, 06:10:18 PM »
How did you select the attributes for the block ??
Did you do a crossing selection
or did you select the Attributes in Order ??
DIW_CADtech
« Reply #3 on: September 16, 2015, 06:51:22 PM »
I tried twice with a crossing window.. bottom left to upper right.. and upper right to bottom left.
DIW_CADtech
« Reply #4 on: September 16, 2015, 06:52:52 PM »
Ya.. BATTORDER did nothing for the properties dialog box..  uhhhhggg that took forever.
Jeff H
« Reply #5 on: September 16, 2015, 06:54:02 PM »
battorder does work you might have to attsync if already inserted.
DIW_CADtech
« Reply #6 on: September 16, 2015, 06:55:26 PM »
PHEW.. man thought I wasted that whole time..
I re-inserted the block and all is well...
man hope I never have to do that again.
« Reply #7 on: September 16, 2015, 07:06:46 PM »
You may find that selecting the attributes in order will solve the issue.
I usually select attributes first then do a crossing to select the balance of items.
DIW_CADtech
« Reply #8 on: September 16, 2015, 07:17:54 PM »
This was 1 of 9 once I had this one created the others took almost no time.
See final block...
FYI this is what the client wanted.... I would never use this block if I could avoid it.
The idea is you drag in the block.. select the one you want then explode and start adding values.
one block.. to rule them all...  LOL
