Author Topic: Reset - Delete all Annotative Scales for all objects  (Read 1233 times)
MSTG007
« on: September 16, 2015, 09:18:33 AM »
Ok. not having a smart time with this one. Can someone help me figure this out? lol. I have several mtexts, dtexts, dimensions, mleaders that all have various scales. All I am trying to do is delete all the scales in those objects except the current scale.
Civil3D 2020
Crank
Re: Reset - Delete all Annotative Scales for all objects
« Reply #1 on: September 16, 2015, 01:54:34 PM »
I'm sure this can be done better, but this is what I use:
(defun c:OnlyCScale (/ l3 l4 l5 l6 l7 SS CS n waarden ent lijst)
(setq SS (ssget "I"))
(command ".undo" "begin")
(while (not SS)(setq SS (ssget)))
(command ".chprop" ss "" "Annotative" "y" "")
(setq CS (getvar "CANNOSCALE"))
(command "-OBJECTSCALE" SS "" "Add" CS "")
(setq n 0 lijst '())
(repeat (sslength SS)
(setq ent (ssname SS n))
(setq waarden (get_ent_scales (entget ent)))
(if waarden (setq lijst (append waarden lijst)))
(setq n (1+ n))
(setq lijst (remove_doubles lijst))
(foreach n lijst
(if (/= n CS)(progn
(if (= (strlen n) 3)(setq l3 (vl-sort (cons n l3)'<)))
(if (= (strlen n) 4)(setq l4 (vl-sort (cons n l4)'<)))
(if (= (strlen n) 5)(setq l5 (vl-sort (cons n l5)'<)))
(if (= (strlen n) 6)(setq l6 (vl-sort (cons n l6)'<)))
(if (= (strlen n) 7)(setq l7 (vl-sort (cons n l7)'<)))
(command "-OBJECTSCALE" SS "" "Del" n "")
(setq lijst (append l3 l4 l5 l6 l7))
(princ (strcat "\n\nThis scale was added " CS))
(if lijst (progn
(princ "\nand these have been removed:")
(foreach n lijst (princ (strcat " " n)))
(command ".undo" "end")
(defun remove_doubles (lst); by Gile
(if lst (cons (car lst) (remove_doubles (vl-remove (car lst) lst))))
(defun get_ent_scales (ent / annotative lijst n schalen collect)
; zie ook: http://www.theswamp.org/index.php?topic=24171.0
(defun collect (key lijst / n return)
(foreach n lijst
(if (= key (car n))
(setq return (cons (cdr n) return))
return
(setq annotative (cdr (assoc 360 ent)))
(if annotative (progn
(setq lijst
(entget (cdr (assoc 350
(entget (cdr (assoc 360
(member '(3 . "AcDbContextDataManager"); Get the right 360-code
(entget annotative)
(foreach n (collect 350 lijst)
(setq schalen (cons
(cdr (assoc 300 (entget (cdr (assoc 340 (entget n))))))
schalen
schalen
« Last Edit: September 16, 2015, 02:04:12 PM by Crank »
MSTG007
« Reply #2 on: September 16, 2015, 03:23:23 PM »
DUDE! you rock. Thank you so much!
Civil3D 2020
