Author Topic: Acad 2014 doesn't find LTYPESHP.SHX  (Read 20783 times)
tedg
« on: September 15, 2015, 10:42:26 AM »
I don't know how long this has been a problem, but my linetypes that use LTYPESHP.SHX don't seem to find this file or the linetypes themselves have a problem.
I get a "Bad definition of FENCELINE1 at line 119 of the..." and so on all of those.
Anyone know what could be wrong?
Can anyone tell me where the LTYPESHP.SHX file is supposed to be?
I have the LTYPESHP.SHX in the support folder (and for giggles I put it in the fonts folder, but I don't think it should be there)
C:\Users\<me>\AppData\Roaming\Autodesk\AutoCAD 2014\R19.1\enu\support
and
C:\Program Files\Autodesk\AutoCAD 2014\Fonts
Thoughts?
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
Re: Acad 2014 doesn't find LTYPESHP.SHX
« Reply #1 on: September 15, 2015, 11:03:58 AM »
C:\Users\mfarrell\AppData\Roaming\Autodesk\AutoCAD 2014\R19.1\enu\Support
check support path(s) in OPTIONS
« Reply #2 on: September 15, 2015, 11:22:43 AM »
If this finds the ltypeshp.shx .. then it's probably something else throwing the error.
  1. (if (findfile "LTYPESHP.SHX")
  2.   (alert (findfile "LTYPESHP.SHX"))
  3.   (alert "Oh noes!!")
  4. )
tedg
« Reply #3 on: September 15, 2015, 11:27:03 AM »
Thanks guys, yes, I do have that path (second in line) in my support paths, and ronjonp's code kicked back that very path.
So now what?
I don't believe I changed anything with those linetypes, I have an OOTB copy too that gives me the same error messages.
« Reply #4 on: September 15, 2015, 11:49:24 AM »
Maybe post a sample drawing?
tedg
« Reply #5 on: September 15, 2015, 12:04:42 PM »
I had a coworker send me his acad.lin and ltypeshp.shx files and I placed them in the support folder and am getting the same issue.
Attached is a drawing and some screen shots. you'll see the fenceline1 is a dashed line without the circles for me anyway.
« Reply #6 on: September 15, 2015, 12:17:10 PM »
PROBLEM IS....
LTYPESHP.shx is a shape file, not a text font file.
« Reply #7 on: September 15, 2015, 12:29:23 PM »
That file works fine for me...
tedg
« Reply #8 on: September 15, 2015, 12:32:34 PM »
Ok thanks.
I tried the same files and paths that others use without an issue for them...
I made sure the support path is there,
What else in an Acad set up be causing this?
I also made sure there were no "copies" of these files anywhere else in my support paths
cadtag
« Reply #9 on: September 15, 2015, 02:02:37 PM »
Just for grins, can you load and use the SHAPEs via the  LOAD command for the shx, and the SHAPE command to place a named shape from it?
huiz
  • Certified Prof C3D
« Reply #10 on: September 16, 2015, 02:42:34 AM »
Probably the shape CIRC1 does not exist.
If someone has changed the linetype in the LIN file and added a new shape to the SHX File, both files has to be distributed. Linetypes get saved inside the drawing once they are loaded, but shapes are not.
It is better to not add shapes to a default AutoCAD SHX file, instead create a new SHX file. If you miss that file, you only get the message that the SHX could not be found, but no linetype errors.
tedg
« Reply #11 on: September 16, 2015, 08:42:14 AM »
Thanks cadtag.
Interesting...
It will allow me to load ltypeshp.shx, but any shape I try to place, it says "not found".
HOWEVER... if I rename that same file and load it, it WILL allow me to place a shape??
WTF?
Command: LOAD <ltypeshp.shx>
Command: SHAPE Enter shape name or [?]: circ1
Shape CIRC1 not found.
Command: LOAD <ltypeshp1.shx>
Specify insertion point:
« Reply #12 on: September 16, 2015, 08:54:27 AM »
Shameless plug but you could just make a waaayyy cooler linetype that does not rely on shapes :)
tedg
« Reply #13 on: September 16, 2015, 09:04:22 AM »
Cool man.
I agree, I tend to use line types with standard text styles/fonts, but this is someone else's drawing, probably why I didn't have an issue until now.
An UPDATE on my last post, to hopefully help troubleshoot the actual problem..
If I keep the renamed "ltypeshp1.shx" in my support folder and change the name of that file in the Acad.lin file for the (5) line types using that file, it works!
In other words, My AutoCAD has an issue with the file name "ltypeshp.shx" not the file
Krushert
  • FREE BEER Tomorrow!!
« Reply #14 on: September 16, 2015, 09:11:39 AM »
I know how it feels.  I have a issue with you calling yourself a Ted.    :-P :whistling: :-D
