Hello!
Did annybody know, why it canīt build a new Civil3d surface, if use metod in a objekt
[CommandMethod("create")]
public void CreateTinSurfaceTest()
Document m_Doc = Application.DocumentManager.MdiActiveDocument;
Database db = m_Doc.Database;
Editor ed = m_Doc.Editor;
using (Transaction m_Tr = db.TransactionManager.StartTransaction())
try
m_SurfaceId = Autodesk.Civil.DatabaseServices.TinSurface.Create(db, "m_NewSurfaceName");
m_Surface = m_SurfaceId.GetObject(OpenMode.ForWrite) as TinSurface;
ed.WriteMessage("Import succeeded: {0} \n {1}", m_SurfaceId.ToString(), db.Filename);
catch (System.Exception e)
ed.WriteMessage("Import failed: {0}", e.Message);
m_Tr.Commit();
By typing command: create - it works > surface "m_NewSurfaceName" would created
But if I call metod from class-object public NewSurface()
Surface newSurf = new Surface();
newSurf.CreateTinSurfaceTest();
I get only error-message "failed to create"
Somebody know a trick, how I can create a surface an other way
