Author Topic: Autodesk::Civil::Land::DatabaseServices::SurfaceOperationPasteSurface  (Read 2685 times)
cadplayer
Hello colleagues!
I have a question how to build in method "SurfaceOperationPasteSurface". For example I want create a new surface "ExampleTINSurface" as code after and than select a surface in drawing that would paste in the created surface. Iīm a little bit new in CivilAPI and have not so much experience. Maybe somebody can help me. Thank you!
[CommandMethod("xx")]
        public void CDS_CreateTinSurface()
            using (tr)
                string surfaceName = "ExampleTINSurface";
                // Select a style to use
                ObjectId surfaceStyleId = civilDoc.Styles.SurfaceStyles[3];
                // Create the surface
                ObjectId surfaceId = TinSurface.Create(surfaceName, surfaceStyleId);
                TinSurface surface = surfaceId.GetObject(OpenMode.ForWrite) as TinSurface;
                tr.Commit();
Re: Autodesk::Civil::Land::DatabaseServices::SurfaceOperationPasteSurface
« Reply #1 on: September 15, 2015, 09:33:21 AM »
surface.PasteSurface(surfToPasteId);
cadplayer
« Reply #2 on: September 25, 2015, 05:26:53 AM »
Hello again!
Yes it works -thanks
« Last Edit: September 26, 2015, 06:39:37 AM by cadplayer »
cadplayer
« Reply #3 on: September 26, 2015, 06:45:36 AM »
Hello!
Did annybody know, why it canīt build a new Civil3d surface, if use metod in a objekt
[CommandMethod("create")]
        public void CreateTinSurfaceTest()
            Document m_Doc = Application.DocumentManager.MdiActiveDocument;
            Database db = m_Doc.Database;
            Editor ed = m_Doc.Editor;
            using (Transaction m_Tr = db.TransactionManager.StartTransaction())
                try
                    m_SurfaceId = Autodesk.Civil.DatabaseServices.TinSurface.Create(db, "m_NewSurfaceName");
                    m_Surface = m_SurfaceId.GetObject(OpenMode.ForWrite) as TinSurface;
                    ed.WriteMessage("Import succeeded: {0} \n {1}", m_SurfaceId.ToString(), db.Filename);
                catch (System.Exception e)
                    ed.WriteMessage("Import failed: {0}", e.Message);
                m_Tr.Commit();
By typing command: create - it works > surface "m_NewSurfaceName" would created
But if I call metod from class-object
public NewSurface()
            Surface newSurf = new Surface();
            newSurf.CreateTinSurfaceTest();
I get only error-message "failed to create"
Somebody know a trick, how I can create a surface an other way
cadplayer
