(setq lst '(1 12 16 21 26 32 40 42 56 66 74))
(parsel lst 24)
'((1 21) (21 42) (42 66) (66 74))
(<= (- 25 1) 24) -> T
(defun parsel (lst q / s ) ;i rl) (setq s (car lst)) (while (< s (last lst)) (setq i 0) (repeat (length lst) (if (> (+ s q) (- (nth i lst) s)) (setq i (1+ i)))) (setq rl (cons (list s (nth (1- i) lst)) rl) s (nth (1- i) lst))) (setq rl (cons (list s (last lst)) rl)) (prin1 (reverse rl)))
GreetingsUsing vanilla Autolisp :Given a sorted list of integers that always starts with 1Code: [Select](setq lst '(1 12 16 21 26 32 40 42 56 66 74))A function to parse the list with a maximum difference between values of a specified number of units ie 24Code: [Select](parsel lst 24)And return a list of lists with the start and end positions:Code: [Select]'((1 21) (21 42) (42 66) (66 74))(1 25) would be validCode: [Select] (<= (- 25 1) 24) -> TAny ideas ? Thanks -DavidPS I haven't figured out what to do if the difference is greater than 24 for 2 adjacent atoms.Here's where I'm at and it aint working !Code: [Select](defun parsel (lst q / s ) ;i rl) (setq s (car lst)) (while (< s (last lst)) (setq i 0) (repeat (length lst) (if (> (+ s q) (- (nth i lst) s)) (setq i (1+ i)))) (setq rl (cons (list s (nth (1- i) lst)) rl) s (nth (1- i) lst))) (setq rl (cons (list s (last lst)) rl)) (prin1 (reverse rl)))Any ideas ? Thanks -David
(defun parsel (lst q / s i rl) (setq s (car lst)) (while (< s (last lst)) (setq i 0) (repeat (length lst) (if (>= q (- (nth i lst) s));include equal to and adding s is not needed (setq i (1+ i)))) (if (not (zerop (- (nth (1- i) lst) s))) (setq rl (cons (list s (nth (1- i) lst)) rl) s (nth (1- i) lst)) (setq s (nth i lst)) )) ;(setq rl (cons (list s (last lst)) rl));Not sure why this is being done (reverse rl));Removed prin1, assuming it was placed for your testing
Not pretty but seems to work with your example
why not '((1 12) (12 16) (16 21) (21 26)..............)
(setq lst '(1 12 16 21 26 32 40 42 56 66 74))(setq dif 2)
What should be the result of the function in this case?:Code: [Select](setq lst '(1 12 16 21 26 32 40 42 56 66 74))(setq dif 2)
