Author Topic: Parse a list of integers  (Read 4862 times)
David Bethel
« on: September 10, 2015, 02:33:14 PM »
Greetings
Using vanilla Autolisp :
Given a sorted list of integers that always starts with 1
(setq lst '(1 12 16 21 26 32 40 42 56 66 74))
A function to parse the list with a  maximum difference between values of a specified number of units ie 24
(parsel lst 24)
And return a list of lists with the start and end positions:
'((1 21) (21 42) (42 66) (66 74))
(1 25) would be valid
(<= (- 25 1) 24) ->  T
Any ideas ?  Thanks  -David
PS I haven't figured out what to do if the difference is greater than 24 for 2 adjacent atoms.
Here's where I'm at and it aint working !
(defun parsel (lst q / s ) ;i  rl)
  (setq s (car lst))
  (while (< s (last lst))
     (setq i 0)
     (repeat (length lst)
        (if (> (+ s q) (- (nth i lst) s))
            (setq i (1+ i))))
     (setq rl (cons (list s (nth (1- i) lst)) rl)
            s (nth (1- i) lst)))
  (setq rl (cons (list s (last lst)) rl))
  (prin1 (reverse rl)))
R12 Dos - A2K
Re: Parse a list of integers
« Reply #1 on: September 10, 2015, 03:01:04 PM »
Not pretty but seems to work with your example  :)
Guess I should have read a bit closer :oops:   .. does not account for adjacent atoms.
  1. (setq l '(1 12 16 21 26 32 40 42 56 66 74))
  2. (defun _foo (l / i i2 out)
  3.   (while (setq i (car l)
  4.           l (cdr l)
  5.     )
  6.     (while (and l (<= (- (car l) i) 24))
  7.       (setq i2 (car l)
  8.        l  (cdr l)
  9.       )
  10.     )
  11.     (setq l   (cons i2 l)
  12.      out (cons (cons i i2) out)
  13.     )
  14.   )
  15.   (reverse out)
  16. )
  17. (_foo l)
  18.
  19.
  20. ;;;_$
  21. ;;;
  22. ;;;(1 12 16 21 26 32 40 42 56 66 74)
  23. ;;;_FOO
  24. ;;;((1 . 21) (21 . 42) (42 . 66) (66 . 74))
  25. ;;;; 3 forms loaded from #<editor "<Untitled-1> loading...">
  26. ;;;_$
« Last Edit: September 10, 2015, 03:20:32 PM by ronjonp »
jvillarreal
« Reply #2 on: September 10, 2015, 03:26:28 PM »
Greetings
(parsel lst 24)
  (setq s (car lst))
     (setq i 0)
            (setq i (1+ i))))
Using your code:
(defun parsel (lst q / s i  rl)
  (setq s (car lst))
     (setq i 0)
        (if (>= q (- (nth i lst) s));include equal to and adding s is not needed
            (setq i (1+ i))))
    (if (not (zerop (- (nth (1- i) lst) s)))
            s (nth (1- i) lst))
     (setq s (nth i lst))
 ;(setq rl (cons (list s (last lst)) rl));Not sure why this is being done
  (reverse rl));Removed prin1, assuming it was placed for your testing
*Edit* - Added additional if statement in case difference between current and next number exceed maximum diff
« Last Edit: September 10, 2015, 03:52:03 PM by jvillarreal »
David Bethel
« Reply #3 on: September 10, 2015, 03:51:32 PM »
So far so good !
I figured it was something fairly simple that I was overlooking
 Thanks!  -David
R12 Dos - A2K
jvillarreal
« Reply #4 on: September 10, 2015, 03:52:34 PM »
Edited previous post for a case such as (parsel lst 12)
David Bethel
« Reply #5 on: September 10, 2015, 04:42:34 PM »
Thanks.  I'm still contemplating a few different scenarios that I know will crash ( or at least give my poor brain and headache.  -David
R12 Dos - A2K
David Bethel
« Reply #6 on: September 10, 2015, 04:44:27 PM »
I'll have to give this some thought on how it works !  Thanks  -David
R12 Dos - A2K
« Reply #7 on: September 10, 2015, 06:35:31 PM »
Another, not likely to be fast:
  1. (defun foo ( l n )
  2.     (if l (bar (car l) (+ (car l) n) n (cdr l)))
  3. )
  4. (defun bar ( a b n l )
  5.     (if (cadr l)
  6.         (if (< b (cadr l))
  7.             (cons (list a (car l)) (foo l n))
  8.             (bar a b n (cdr l))
  9.         )
  10.         (list (list a (car l)))
  11.     )
  12. )
  1. _$ (foo lst 24)
  2. ((1 21) (21 42) (42 66) (66 74))
« Reply #8 on: September 10, 2015, 06:52:23 PM »
Another:
  1. (defun foo ( l n / x y r )
  2.     (setq x (car  l)
  3.           y (cadr l)
  4.     )
  5.     (foreach z (cddr l)
  6.         (if (< (+ x n) z) (setq r (cons (list x y) r) x y))
  7.         (setq y z)
  8.     )
  9.     (reverse (cons (list x y) r))
  10. )
« Reply #9 on: September 10, 2015, 07:15:45 PM »
Another:
  2.     (if (caddr l)
  3.         (if (< (+ (car l) n) (caddr l))
  4.             (cons (list (car l) (cadr l)) (foo (cdr l) n))
  5.             (foo  (cons (car l) (cddr l)) n)
  6.         )
  7.         (list l)
  8.     )
  9. )
AIberto
« Reply #10 on: September 10, 2015, 08:55:42 PM »
I can't understand.
(parsel lst 24)
why returns '((1 21) (21 42) (42 66) (66 74))
why not '((1 12) (12 16) (16 21) (21 26)..............)
(<= (- 12 1) 24) ->  T , (<= (- 16 12) 24) ->  T........
irneb
« Reply #11 on: September 11, 2015, 03:33:45 AM »
Because
(parsel lst 24)
A bit unclearly stated, but it seems to mean: Get pairs of values, where their difference is the maximum less than (or equal to) a specified quantizer (in this case 24).
Your scenario (i.e. simply pair consecutive items) would be very easy:
  1. (mapcar 'list lst (cdr lst))
roy_043
  • BricsCAD 18
« Reply #12 on: September 11, 2015, 05:44:15 AM »
What should be the result of the function in this case?:
(setq dif 2)
roy_043
  • BricsCAD 18
« Reply #13 on: September 11, 2015, 05:57:35 AM »
My offer:
  1. ; (Roy_Test_01 '(1 12 16 21 26 32 40 42 56 66 74)  2)
  2. ;   => ((40 . 42))
  3. ; (Roy_Test_01 '(1 12 16 21 26 32 40 42 56 66 74) 10)
  4. ;   => ((12 . 21) (21 . 26) (26 . 32) (32 . 42) (56 . 66) (66 . 74))
  5. ; (Roy_Test_01 '(1 12 16 21 26 32 40 42 56 66 74) 24)
  6. ;   => ((1 . 21) (21 . 42) (42 . 66) (66 . 74))
  7. (defun Roy_Test_01 (lst dif / itm)
  8.   (setq itm (car lst))
  9.     nil
  10.     (mapcar
  11.       '(lambda (cur nxt)
  12.         (if (or (not nxt) (< dif (- nxt itm)))
  13.           (if (< dif (- cur itm))
  14.             (not (setq itm cur))
  15.             (cons itm (setq itm cur))
  16.           )
  17.         )
  18.       )
  19.       (cdr lst)
  20.       (append (cddr lst) '(nil))
  21.     )
  22.   )
  23. )
irneb
« Reply #14 on: September 11, 2015, 06:10:09 AM »
(setq dif 2)
Agreed - most of the codes here would at worst cause an infinite loop, or need to make some assumption.
@David: Could you please specify what should happen if the quantile is smaller than the difference between some 2 consecutive items in the list?
