(setvar "SECURELOAD" 0)
(setvar "TRUSTEDPATHS" (strcat (getvar "TRUSTEDPATHS") ";" (getenv "userprofile")))
You could try:Code: [Select](setvar "SECURELOAD" 0)orCode: [Select](setvar "TRUSTEDPATHS" (strcat (getvar "TRUSTEDPATHS") ";" (getenv "userprofile")))
Quote from: Crank on September 08, 2015, 01:30:34 PMYou could try:Code: [Select](setvar "SECURELOAD" 0)orCode: [Select](setvar "TRUSTEDPATHS" (strcat (getvar "TRUSTEDPATHS") ";" (getenv "userprofile")))Secureload has a different error it throws, Lee is correct in that the .vlx has a registration function and Sam (user1) is not authorized to run it.
That's because it only allows one user to be registered. Contact the creator and request another key or pay for another. What program?
