A little edit version of Aleksandr Smirnov (ASMI)
Makes objects temporarily invisible and visible return of all or some
(defun c:invis(/ errCount wMode objSet showset actDoc *error*)
;; INVIS.LSP - Makes objects temporarily invisible and ;;
;; visible return of all or some ;;
;; Command(s) to call: INVIS ;;
;; THIS PROGRAM AND PARTS OF IT MAY REPRODUCED BY ANY METHOD ON ANY ;;
;; MEDIUM FOR ANY REASON. YOU CAN USE OR MODIFY THIS PROGRAM OR ;;
;; PARTS OF IT ABSOLUTELY FREE. ;;
;; THIS PROGRAM PROVIDES 'AS IS' WITH ALL FAULTS AND SPECIFICALLY ;;
;; DISCLAIMS ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS ;;
;; FOR A PARTICULAR USE. ;;
;; V1.1, 11th Apr 2005, Riga, Latvia ;;
;; © Aleksandr Smirnov (ASMI) ;;
;; For AutoCAD 2000 - 2008 (isn't tested in a next versions) ;;
;;http://www.cadtutor.net/forum/showthread.php?43876-AsmiTools ;;
;; V1.2, 02 June 2011, Minsk, Belarus ;;
;; © Vladimir Azarko (VVA) ;;
;; For AutoCAD 2000 - 2011 (isn't tested in a next versions) ;;
;; Add mode "Show some object" ;;
;;http://www.cadtutor.net/forum/showthread.php?59655 ;;
(defun put_Visible_Prop(Object Flag)
(vl-catch-all-error-p
(vl-catch-all-apply
'vla-put-visible (list Object Flag)))
(setq errCount(1+ errCount))
); end if
); end of put_Visible_Prop
(defun Set_to_List(SelSet)
(mapcar 'vlax-ename->vla-object
(vl-remove-if 'listp
(mapcar 'cadr(ssnamex SelSet))))
); end of Set_to_List
(defun errMsg()
(if(/= 0 errCount)
(princ(strcat ", " (itoa errCount)
" were on locked layer."))
); end if
); end of errMsg
(setq actDoc(vla-get-ActiveDocument
(vlax-get-Acad-object))
errCount 0); end setq
(vla-StartUndoMark actDoc)
(initget "Visible Invisible Show" 1)
(setq wMode
(getkword "\nMake objects [Visible all/Invisible/Show some invisible objects]: "))
((and
(= wMode "Visible")
(setq objSet(ssget "_X" '((60 . 1))))
); end and
(setq objSet(Set_to_List objSet))
(mapcar
'(lambda(x)(put_Visible_Prop x :vlax-true))objSet)
(princ
(strcat "\n<< "
(itoa(-(length objSet)errCount))
" now visible" (errMsg) " >>"))
);_ # condition
((and
(= wMode "Show")
); end and
(mapcar
(princ
(strcat "\n<< "
(princ "\nSelect objects to show")
(if (setq showset (ssget "_:L"))
(setq showset(Set_to_List showset))
(foreach item showset
(setq objSet (vl-remove item objSet))
(mapcar
'(lambda(x)(put_Visible_Prop x :vlax-false))objSet)
);_ # condition
(t
(if(not(setq objSet(ssget "_I")))
(setq objSet(ssget))
); end if
(if objSet
(mapcar
(princ
(strcat "\n<< "
" now invisible" (errMsg) " >>"))
; end if
); end progn
); end if
(vla-EndUndoMark actDoc)
); end of c:invis
(princ "\n[Info] http://www.cadtutor.net/forum/showthread.php?59655 [Info]")
(princ "\n[Info] Type INVIS to make objects invisible or visible. [Info]")(princ)
