Author Topic: Is there a trick to editor.Command()  (Read 2920 times)
nobody
  • .net stuff
« on: September 03, 2015, 12:13:57 AM »
Okay...so this is a pretty noobish question but I've avoided using ed.Command() forever simply because I have always got the error in the attached image. Can someone please clue me in to what reference I need to load and what "using" i should be using :) Thank you!
Jeff H
Re: Is there a trick to editor.Command()
« Reply #1 on: September 03, 2015, 12:18:12 AM »
Means Editor Object does not contain a method named Command.
Your using older version or missing a reference, or  never created a extension method for it.
nobody
  • .net stuff
« Reply #2 on: September 03, 2015, 12:22:52 AM »
Right...need to know which reference :)
I thought maybe interop or interop common but guess those aren't it.
huiz
  • Certified Prof C3D
« Reply #3 on: September 03, 2015, 12:43:46 AM »
  internal const char ESC = '\x1B';
  internal const char RETURN = '\xD';
  internal static void SendCommandToCommandLine(string Command, bool Escape = true) {
    string EscapeString = string.Empty;
    if (Escape == true) { EscapeString = ESC.ToString() + ESC.ToString(); }
    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.SendStringToExecute(EscapeString + Command + RETURN, true, false, true);
nobody
  • .net stuff
« Reply #4 on: September 03, 2015, 12:54:24 AM »
Thanks! I'll give that a shot :)
nobody
  • .net stuff
« Reply #5 on: September 03, 2015, 01:13:14 AM »
Is Editor.Command() perhaps not a 2014 item?
Jeff_M
  • C3D user & customizer
« Reply #6 on: September 03, 2015, 01:13:47 AM »
The Editor Command() and CommandAsync() methods were introduced in the 2015 API. So if coding for, or targeting, an earlier release you won't have those methods available.
nobody
  • .net stuff
« Reply #7 on: September 03, 2015, 01:22:31 AM »
Awe! That's it bahaha...Was driving me crazy :)
Thanks!!
