Author Topic: Civil 3d: Why Doesn't GeneralSegmentLabel.StyleName = "" Work?  (Read 1706 times)
nobody
  • .net stuff
Trying to change a line / curve label using GeneralSegmentLabel.StyleName = ""; but it throws this error.
Am I doing it incorrectly?
Code - C#: [Select]
  1. foreach (ObjectId entid in mycoll)
  2.                 {
  3.
  4.                     GeneralSegmentLabel oNoteLabel = (GeneralSegmentLabel)myT.GetObject(entid, OpenMode.ForRead);
  5.
  6.                     if (oNoteLabel.StyleName.ToString().Contains("partialnamehere"))
  7.                     {
  8.                         oNoteLabel.StyleName = "styleIwant";
  9.                     }
  10.
huiz
  • Certified Prof C3D
Re: Civil 3d: Why Doesn't GeneralSegmentLabel.StyleName = "" Work?
« Reply #1 on: August 31, 2015, 04:35:36 AM »
It says the Label Style Name does not exist. Are you sure it exists in the drawing?
I use the .StyleName property too, with other Civil3D objects, and have no problem. To be sure it works fine I always use a Transaction and open the objects ForWrite.
nobody
  • .net stuff
« Reply #2 on: August 31, 2015, 05:11:45 AM »
Positive it's in there but will try the write thing. In fact, I changed it manually, then had it list the name to be sure. Really strange :/
« Reply #3 on: August 31, 2015, 10:04:07 AM »
You cannot use a Child Stylename when assigning the StyleName property. Get, and use, the ObjectId instead.
