Having used data extraction in Autocad 2012, I could list a table of blocks along with the X and Y coordinate of each block.
I am trying to do the same thing in the 2015 version and I cannot separate the X and Y coordinates into different Columns. I used to select "Position X" and "Position Y". Now I can only select "Position" and the column produces "xcoord,ycoord,zcoord".
Has anyone else had this issue and is there a way to split them up?
