Author Topic: Data Extraction in Acad 2015  (Read 2834 times)
EoinC
« on: August 27, 2015, 10:05:48 AM »
Having used data extraction in Autocad 2012, I could list a table of blocks along with the X and Y coordinate of each block.
I am trying to do the same thing in the 2015 version and I cannot separate the X and Y coordinates into different Columns. I used to select "Position X" and "Position Y". Now I can only select "Position" and the column produces "xcoord,ycoord,zcoord".
Has anyone else had this issue and is there a way to split them up?
Krushert
  • FREE BEER Tomorrow!!
Re: Data Extraction in Acad 2015
« Reply #1 on: August 27, 2015, 10:30:32 AM »
First off, Welcome to TheSwamp!
Second I am still running 2014 so I can not test it.  If this is as you say then that would be lousy thing to do to us
Keep us informed on what you find out.  I like the data extraction command
ChrisCarlson
« Reply #2 on: August 28, 2015, 08:22:13 AM »
I'm not sure about 2015, but ACAD2016 seems to have fixed or works as expected
« Reply #3 on: August 28, 2015, 08:34:07 AM »
Works fine for me.
EoinC
« Reply #4 on: August 28, 2015, 08:43:23 AM »
Thank you for the replies.
Here is a screenshot of what I am looking at. It seems to be an internal setting within my ACAD but I don't know where I can change this.
I'll let ye know if I find a fix, but thanks anyway for yer help.
« Reply #5 on: August 28, 2015, 08:49:38 AM »
Are you selecting only blocks?
EoinC
« Reply #6 on: August 28, 2015, 09:36:18 AM »
Yes. Should I be selecting more?
« Reply #7 on: August 28, 2015, 09:47:21 AM »
Weird. You could export to a comma-delimited (csv) file then parse it with excel.
EoinC
« Reply #8 on: August 28, 2015, 09:50:42 AM »
It is strange because I used it a few weeks ago with 2012. It must be a setting on my ACAD somewhere.
I have used the method of exporting to excel but I was hoping someone would have experienced the same issue and solved it within CAD.
Thank you for your time and suggestions. It's just frustrating because I know it can be done.
Cathy
« Reply #9 on: August 28, 2015, 03:19:35 PM »
It sure looks like you've selected a viewport.  Perhaps try it by selecting only a single block and see if it works?
EoinC
« Reply #10 on: August 31, 2015, 12:47:53 PM »
There is a viewport included in the screenshots I put up, however they were taken as part of a quick example I did. I have the same issue with just blocks, even when I select the block by highlighting it.
Jeff H
« Reply #11 on: August 31, 2015, 01:50:11 PM »
What is COORDS setting?
EoinC
« Reply #12 on: September 01, 2015, 04:37:03 AM »
The COORDS variable was set to 1. I have changed it to 0, 2, 3 but got the same result. I am working in the WCS. Does this answer your question? Thank you again for your help.
It seems like changing a setting like this would solve my problem.
