Author Topic: printerconfigpath automation error  (Read 2231 times)
dubb
« on: August 26, 2015, 05:29:14 PM »
(setq PreferenceFiles (vla-get-files (vla-get-preferences (vlax-get-acad-object))))
;print/plotter settings
(setq AddPrintPath (strcat "n:\\cad_support\\plotter"))
(setq CurrentPrintPath (strcat (vla-get-PrinterConfigPath PreferenceFiles)))
(setq NewPrintPath (strcat AddPrintPath";"CurrentPrintPath))
(vla-put-printerconfigpath PreferenceFiles NewPrintPath)
I get an error
Automation Error. Invalid Argument
What am I doing wrong? :nerdyembarassed:
Re: printerconfigpath automation error
« Reply #1 on: August 26, 2015, 05:47:01 PM »
I don't see anything wrong with your code - perhaps there is a bug with the ActiveX printerconfigpath property.
Try the following alternative method, changing the registry value directly:
  1. (setq new "n:\\cad_support\\plotter"
  2.       cur (getenv "PrinterConfigDir")
  3. )
  4.     (setenv "PrinterConfigDir" (strcat new ";" cur))
  5. )
dubb
« Reply #2 on: August 26, 2015, 05:56:58 PM »
This works Thanks Lee.
  3. )
  5. )
ChrisCarlson
« Reply #3 on: August 27, 2015, 08:26:47 AM »
I'm not sure what you are even trying to do ? All you really need to do is
Not sure why you are pulling the old config path?
« Reply #4 on: August 27, 2015, 08:44:28 AM »
The OP is adding a new path to the existing set of paths.
ChrisCarlson
« Reply #5 on: August 27, 2015, 10:27:59 AM »
His snippet seems to works on Vanilla 2016. He just needs to add a check to prevent duplicate line items.
Is there an advantage to writing to the registry directly vs ActiveX?
