Author Topic: Lock and unlock a document  (Read 2328 times)
latour_g
« on: August 26, 2015, 12:06:16 PM »
I would like to know if using
using (doc.LockDocument())
is better than using :
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
DocumentLock loc = doc.LockDocument();
loc.Dispose();
Right now, I'm using doc.LockDocument() at a lot of place in my code.  I'm wondering if I choose change them all for the other method because user sometime get an error message when trying to save (Command still active).  I have checked everywhere in my code, there is always a loc.Dispose() but I might have miss something.
Thank youbefore printing this email.
Andrey Bushman
Re: Lock and unlock a document
« Reply #1 on: August 26, 2015, 12:17:04 PM »
If you use the using block, then document will be unlocked even if an unhandled exception happens. If you use
DocumentLock loc = doc.LockDocument();then you are to use 'try\catch\finally' block and unlock document in the 'finally' block.
« Last Edit: August 26, 2015, 12:24:08 PM by Andrey Bushman »
latour_g
« Reply #2 on: August 26, 2015, 01:20:45 PM »
Thanks for your answer.
Suppose I have this :
try { db.LoadLineTypeFile(clType, cLinFile); }
catch { }
Can I unlock the document in the catch since there is nothing ?
And one last question if I may.  If I want to replace this :
DBObjectCollection objs = new DBObjectCollection();
BlockReference br = tr.GetObject(blkId, OpenMode.ForWrite) as BlockReference;
with "using document lock"
should I declare using (doc.LockDocument()) inside or outside using (Transaction tr = db.TransactionManager.StartTransaction()) ?
or
« Last Edit: August 26, 2015, 01:34:23 PM by latour_g »
Andrey Bushman
« Reply #3 on: August 26, 2015, 01:28:46 PM »
This is bad way. Why don't you need to do at in the finally?
latour_g
« Reply #4 on: August 26, 2015, 01:33:19 PM »
I thought "finally" was useless if there was nothing to be done in the catch.
I have edited my previous post, can you take a look at it please ?
Andrey Bushman
« Reply #5 on: August 26, 2015, 01:40:45 PM »
I think both variants are correct.
Content of the finally block will be called always. Content of the catch block will be called only if exception occurs. Read about the finally in the C# specification, please.
latour_g
« Reply #6 on: August 26, 2015, 01:45:38 PM »
Yes you are right.  My bad, I was confused when I talked about try/catch !
Thanks for your answer !
Andrey Bushman
« Reply #7 on: August 26, 2015, 01:58:20 PM »
No problem. Welcome. :)
gile
  • Marseille, France
« Reply #8 on: August 26, 2015, 02:09:14 PM »
By my side I use to write :
Code - C#: [Select]
  1. using (doc.LockDocument())
  2. using (var tr = db.TransactionManager.StartTransaction())
  3. {
  4.     // ...
  5. } // <- the transaction is disposed, then the document is unlocked (disposed)
Keith Brown
« Reply #9 on: August 26, 2015, 04:19:04 PM »
Code - C#: [Select]
  3. {
  4.     // ...
+1
