Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Arc/Curve Data
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Arc/Curve Data (Read 1820 times)
nobody
Swamp Rat
.net stuff
Arc/Curve Data
on:
August 25, 2015, 10:25:07 PM »
Do arcs have tangent / delta properties or do they need to be calc'd out? If so anyone have an example?
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: Arc/Curve Data
Reply #1 on:
August 25, 2015, 11:26:43 PM »
Arc.TotalAngle
perhaps ...
Code - C#:
[Select]
// Properties
public
Point3d Center
Category
"Geometry"
get
set
UnitType
UnitType
AngleNotTransformed
public
double
EndAngle
Category
"Geometry"
get
set
UnitType
UnitType
Distance
public
double
Length
Category
"Geometry"
get
public
Vector3d Normal
Category
"Geometry"
get
set
UnitType
UnitType
Distance
public
double
Radius
Category
"Geometry"
get
set
UnitType
UnitType
AngleNotTransformed
public
double
StartAngle
Category
"Geometry"
get
set
UnitType
UnitType
Distance
public
double
Thickness
Category
"General"
get
set
UnitType
UnitType
AngleNotTransformed
public
double
TotalAngle
Category
"Geometry"
get
Logged
nobody
Swamp Rat
.net stuff
Re: Arc/Curve Data
Reply #2 on:
August 25, 2015, 11:33:33 PM »
Looks like that will work for the delta. Thank you!
Logged
Mesozoic relic
Seagull
Re: Arc/Curve Data
Reply #3 on:
August 25, 2015, 11:40:41 PM »
I'm sure it will.
and Tangent would be rad * tan (delta*0.5) I bet.
added:
Though I s'pose it depends on your usage of the word Tangent.
I assumed:
http://autocad.wikia.com/wiki/File:Arc_relationships.png
Last Edit: August 25, 2015, 11:52:53 PM by Kerry
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
Arc/Curve Data
