Author Topic: Delete a line of complete coincidence  (Read 5011 times)
mianbaoche
« on: August 25, 2015, 04:19:34 AM »
Delete a line of complete coincidence,This method is slow!
  1. (defun c:tt()
  2.   (setq lst (mapcar '(lambda (x)  (list x (cdr (assoc 10 (entget x))) (cdr (assoc 11 (entget x)))))(vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "LINE")))))))
  3.         t1  (getvar "TDUSRTIMER"))
  4.   (item_sort lst)
  5.   (princ (strcat "\n""TIME:" (rtos (* 86400 (- (getvar "TDUSRTIMER") t1)) 2 0)))
  6.   (princ)
  7.   )
  8.
  9.
  10. (defun item_sort ( l / c l r x e  aa ll)
  11.      (while l
  12.        (setq  x (car l)
  13.               e (list x)
  14.               l (cdr l)
  15.           )
  16.          (foreach y l
  17.                (if (or
  18.                      (and (equal (distance (cadr y) (cadr x)) 0 1e-6)(equal (distance (caddr y) (caddr x)) 0 1e-6))
  19.                      (and (equal (distance (caddr y) (cadr x)) 0 1e-6)(equal (distance (cadr y) (caddr x)) 0 1e-6))
  20.                      )
  21.                (setq e (cons y e))
  22.                (setq ll (cons y ll))
  23.                 )
  24.            )
  25.          (if (> (length e) 1) (foreach a e (entdel (car a))))
  26.           (setq  l ll  e nil  ll nil)
  27. ))
  28.
  29.
  30.
  31.
  32.
  33.
ribarm
  • Marko Ribar, architect
Re: Delete a line of complete coincidence
« Reply #1 on: August 25, 2015, 04:46:50 AM »
If I understood correctly, maybe this :
  1. (defun c:remcoincidentlines ( / uniquelilst ss ssl ssrl ssreml )
  2.
  3.   (defun uniquelilst ( l )
  4.     (if l (cons (car l) (vl-remove-if '(lambda ( x ) (or
  5.                                                        (and (equal (cdr (assoc 10 (entget (car l)))) (cdr (assoc 10 (entget x))) 1e-6) (equal (cdr (assoc 11 (entget (car l)))) (cdr (assoc 11 (entget x))) 1e-6))
  6.                                                        (and (equal (cdr (assoc 10 (entget (car l)))) (cdr (assoc 11 (entget x))) 1e-6) (equal (cdr (assoc 11 (entget (car l)))) (cdr (assoc 10 (entget x))) 1e-6))
  7.                                                      )
  8.                                        ) (uniquelilst (cdr l))
  9.                         )
  10.           )
  11.     )
  12.   )
  13.
  14.   (setq ss (ssget "_:L" '((0 . "LINE"))))
  15.   (setq ssl (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
  16.   (setq ssrl (uniquelilst ssl))
  17.   (setq ssreml (vl-remove-if '(lambda ( x ) (vl-position x ssrl)) ssl))
  18.   (foreach e ssreml
  19.     (entdel e)
  20.   )
  21.   (princ)
  22. )
  23.
Or a little faster Vlisp variant...
  2.
  3.
  4.   (defun uniquelilst ( l )
  5.     (if l (cons (car l) (vl-remove-if '(lambda ( x ) (or
  6.                                                        (and (equal (vlax-curve-getstartpoint (car l)) (vlax-curve-getstartpoint x) 1e-6) (equal (vlax-curve-getendpoint (car l)) (vlax-curve-getendpoint x) 1e-6))
  7.                                                        (and (equal (vlax-curve-getstartpoint (car l)) (vlax-curve-getendpoint x) 1e-6) (equal (vlax-curve-getendpoint (car l)) (vlax-curve-getstartpoint x) 1e-6))
  8.                                                      )
  9.                                        ) (uniquelilst (cdr l))
  10.                         )
  11.           )
  12.     )
  13.   )
  14.
  15.   (setq ss (ssget "_:L" '((0 . "LINE"))))
  16.   (setq ssl (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
  17.   (setq ssrl (uniquelilst ssl))
  18.   (setq ssreml (vl-remove-if '(lambda ( x ) (vl-position x ssrl)) ssl))
  19.   (foreach e ssreml
  20.     (entdel e)
  21.   )
  22.   (princ)
  23. )
  24.
« Last Edit: August 25, 2015, 07:28:58 AM by ribarm »
M.R. on Youtube
« Reply #2 on: August 25, 2015, 05:01:08 AM »
This method is slow
I haven't tested the speed , but say that it takes 3 seconds to run.
Would you consider 1.5 seconds satisfactory ?
Assume the saving can be made ... perhaps it can't ....
Assume you use it every working day for a year, that will be a saving of 5 minutes.
Assume you have 4 people in your office who use it ... that's a saving of 20 minutes.
To be financially viable the changes can't take longer that 20 minutes ... if the routine can be shortened..
The first thing you could do is spend 2 minutes changing the variable names so anyone reading the code knows immediately what each variable represents.
just curious ... why is the routine removing the coincident line and the line overlayed ?
« Reply #3 on: August 25, 2015, 05:17:24 AM »
This may be marginally quicker:
  1. (defun c:linedupes ( / e i l p q r s x )
  2.     (if (setq s (ssget "_:L" '((0 . "LINE"))))
  3.         (progn
  4.             (repeat (setq i (sslength s))
  5.                 (setq e (ssname s (setq i (1- i)))
  6.                       x (entget e)
  7.                       l (cons (list (cdr (assoc 10 x)) (cdr (assoc 11 x)) e) l)
  8.                 )
  9.             )
  10.             (while l
  11.                 (setq p (caar  l)
  12.                       q (cadar l)
  13.                 )
  14.                 (foreach y (cdr l)
  15.                     (if (or (and (equal (car y) p 1e-6) (equal (cadr y) q 1e-6))
  16.                             (and (equal (car y) q 1e-6) (equal (cadr y) p 1e-6))
  17.                         )
  18.                         (entdel (caddr  y))
  19.                         (setq r (cons y r))
  20.                     )
  21.                 )
  22.                 (setq l r r nil)
  23.             )
  24.         )
  25.     )
  26.     (princ)
  27. )
Or perhaps:
  1. (defun c:linedupes ( / e i l p q s x )
  3.         (progn
  6.                       x (entget e)
  8.                 )
  9.             )
  10.             (while
  12.                       q (cadar l)
  13.                       l
  14.                     (vl-remove-if
  15.                        '(lambda ( y )
  16.                             (if (or (and (equal (car y) p 1e-6) (equal (cadr y) q 1e-6))
  17.                                     (and (equal (car y) q 1e-6) (equal (cadr y) p 1e-6))
  18.                                 )
  19.                                 (entdel (caddr y))
  20.                             )
  21.                         )
  22.                         (cdr l)
  23.                     )
  24.                 )
  25.             )
  26.         )
  27.     )
  28.     (princ)
  29. )
(The above is untested)
« Last Edit: August 25, 2015, 06:28:10 AM by Lee Mac »
mianbaoche
« Reply #4 on: August 25, 2015, 08:35:54 AM »
Thanks for all!I need to learn!
dgorsman
« Reply #5 on: August 25, 2015, 10:21:03 AM »
This method is slow
I approach such evaluations from another perspective: for one person saving 5 minutes over a year, that's in a 50 week x 40 hour/week schedule, or 2000 hours.  Even saving 4 people a cumulative 20 minutes, its negligible.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #6 on: August 25, 2015, 10:30:58 AM »
absolutely,
It's the principle I was trying to express ... sometimes the scale is minor but the essence of the evaluation holds.
added:
Just to clarify that:
I've seen people spend a large effort for minimal return ... In fact I've done it myself a couple of times.
Throwing time and money at something because it seems 'too slow' or 'not pretty'  is an easy trap to fall into.
« Last Edit: August 25, 2015, 10:56:11 AM by Kerry »
AIberto
« Reply #7 on: August 25, 2015, 10:34:37 AM »
This method is slow
Less drink a cup of coffee,  can saving 20 minutes , a man , Less smoke a cigarette, can saving 10 minutes ...
danallen
« Reply #8 on: August 25, 2015, 12:55:33 PM »
Is It Worth the Time?
https://xkcd.com/1205/
cmwade77
« Reply #9 on: August 25, 2015, 02:32:03 PM »
It is a valid point, but you also have to factor in how many other people in your company will use it as well?
cmwade77
« Reply #10 on: August 25, 2015, 02:40:21 PM »
If I am understanding correctly, wouldn't this work:
(defun c:tt (/)
     (command "._-overkill" "All" "" "_O" "0" "_I" "_A" "_P" "_N" "_T" "_N" "_E" "_N" "_A" "Y" "")
And it would be by far the fastest method, at least in versions of AutoCAD since Overkill has been a command instead of an express tool. I believe it was around 2012 or so that this became a built-in command.
ribarm
« Reply #11 on: August 25, 2015, 03:21:27 PM »
(defun c:tt (/)
It would be the fastest way if OP didn't wanted to overkill only coincident lines. So the lisp is more appropriate solution IMHO.
M.R. on Youtube
David Bethel
« Reply #12 on: August 25, 2015, 03:46:14 PM »
Maybe I'm missing something here.  All LINE point values are stored as WCS.  So to me an AutoCAD line of coincidence must have equal X Y & Z axis values ( to within a fuzz factor )  ?
Or do you consider a LINE coincidental if the points are reversed:?
-David
« Last Edit: August 25, 2015, 03:49:38 PM by David Bethel »
R12 Dos - A2K
dgorsman
« Reply #13 on: August 25, 2015, 05:20:57 PM »
That factors out.  Lets say you have ten users.  That may be ten times the time saved, but over the year that's also ten times more man-hours.  The values stay constant relative to each other.
try {GreatPower;}
   finally
      {MasterBasics;}
cmwade77
« Reply #14 on: August 25, 2015, 05:26:56 PM »
No, what I am saying is a CAD Manager invests say 10 hours in creating a LISP routine that 50 users are going to use. That is a lot different than investing 10 hours in something one user will use.
That being said, let's take a look at the numbers with a command that gets used a modest 25 times in one day per user. Let's say the command typically takes 2 minutes to run and you are able to cut it down to 1 minute. Well, each user has now saved 25 minutes per day. At 50 work weeks of 5 days a week, that equals out to be approximately 100 hours a year per user. At an average billable rate of $50 per hour, that is $5,000 per year, per user in billable times that has been saved. And that is saving just 25 minutes per day per user. Now, if you are a company with say 50 users, that's $250,000 per year in billable time that is saved. Even for just one user, that's three AutoCAD licenses of savings each year.
Even at half the savings, that is still a huge chunk of money. It's amazing how fast the savings can add up, isn't it?
So was 10 hours of the CAD Manager's time, even at the full $50 per hour billable rate, which would come out to $500, a good investment? I think it was given the end savings per year and hopefully it is something the CAD Manager doesn't need to revisit every single year, then the savings are even better.
« Last Edit: August 25, 2015, 06:08:28 PM by cmwade77 »
