Author Topic: Adding Numbers  (Read 8119 times)
cmwade77
Re: Adding Numbers
« Reply #15 on: August 20, 2015, 05:33:58 PM »
One more error that I have discovered is that if the user removes an attribute from the selection set, then readds the block by say selecting another attribute, it will also include the removed attribute value in the total. I am not sure how to use ssnamex to determine if the pick point or crossing window was used to remove or add an object, any ideas?
« Last Edit: August 20, 2015, 05:45:35 PM by cmwade77 »
Re: Adding Numbers
« Reply #16 on: August 20, 2015, 07:47:43 PM »
Try this: (atof "100 ABC") .. if you're just adding numbers it should be fine.
cmwade77
Re: Adding Numbers
« Reply #17 on: August 20, 2015, 08:03:46 PM »
Interesting, I will have to play more with it, I was getting errors on some strings.
cmwade77
Re: Adding Numbers
« Reply #18 on: August 21, 2015, 11:55:56 AM »
Ok, but (atof "test 100 test") returns 0 instead of 100. I don't plan on needing to be able to do this, but who knows what one of my users might do.
Re: Adding Numbers
« Reply #19 on: August 21, 2015, 12:09:39 PM »
But you're using the "che_str2num" function ?
(read "test 100 test") returns a symbol of TEST .. maybe I'm missing the point?
cmwade77
Re: Adding Numbers
« Reply #20 on: August 21, 2015, 12:15:07 PM »
But you're using the "che_str2num" function ? (read "test 100 test") returns a symbol of TEST. Maybe i'm missing the point?
But if you look what this function is doing is pulling the numbers out of the string and making sure they are in the correct order, then using read on that string to get the result.
So try this:
(defun che_Str2Num (str / test numlst lst)
(if (= (substr str 1 1) ".")
(setq Str (strcat "0" str))
(setq test (list 46 48 49 50 51 52 53 54 55 56 57))
(setq charlst (vl-string->list str))
(foreach x charlst
(if (member x test)
(setq lst (cons x lst))
(setq lst (cons 32 lst))
(read (vl-list->string (reverse lst)))
(che_str2num "TEST 100 TEST")
And you will see that it will return 100 and not TEST.
The other key to this, which is necessary for another routine that the function gets used in is that this keeps the correct number of decimal places.
Re: Adding Numbers
« Reply #21 on: August 21, 2015, 12:26:35 PM »
So try this:
      (foreach x charlst
         (if (member x test)
That's why I said "but you're using the che_Str2Num function". Your comparison here is comparing apple to oranges.  :P
This is all I was getting at:
  1. (setq str "test .100 test")
  2.        (mapcar '(lambda (x)
  3.              (if   (or (= x 46) (<= 48 x 57))
  4.                (chr x)
  5.                ""
  6.              )
  7.            )
  8.           (vl-string->list str)
  9.        )
  10.      )
  11. )
  12. (if str
  13.   (progn ;; Number
  14.     (atof str)
  15.     ;; Boom
  16.     (read str)
  17.     ;; No Boom
  18.     (read (strcat "0" str))
  19.   )
  20. )
« Last Edit: August 21, 2015, 12:44:34 PM by ronjonp »
Re: Adding Numbers
« Reply #22 on: August 21, 2015, 12:42:22 PM »
Admittedly I haven't thoroughly read the entire thread, but where the 'che_str2num' function is concerned, perhaps my Parse Numbers function may be of help?
cmwade77
Re: Adding Numbers
« Reply #23 on: August 21, 2015, 07:04:35 PM »
Ok, but your code doesn't seem to work with the string "test .100 test", it returns 100 instead of .100. In all fairness my routine presently crashes with this, but I am working on a fix.
cmwade77
Re: Adding Numbers
« Reply #24 on: August 21, 2015, 07:55:01 PM »
I fixed the decimal point issues in my code and I now provide some form of visual feedback as to which attributes and pieces of text were included in the total. I am quite sure there is a lot that can be done to improve this code, but it seems to at least work for the time being. I believe that I have accounted for most errors, except the removing of attributes from the selection set, as I mentioned before. I wonder if Lee might already have a solution for how to tell if a point picked in a selection set was for adding or removing something?
The updated code is in the first post.
cmwade77
Re: Adding Numbers
« Reply #25 on: August 21, 2015, 08:00:31 PM »
So try this:
      (foreach x charlst
         (if (member x test)
  4.                (chr x)
  5.                ""
  6.              )
  7.            )
  9.        )
  10.      )
  11. )
  12. (if str
  14.     (atof str)
  15.     ;; Boom
  16.     (read str)
  17.     ;; No Boom
  19.   )
  20. )
Yeah, the problem with this method is it adds a 0, even if the first character isn't a ., which is a compatibility problem with other code that will eventually be incorporated into this routine.
Re: Adding Numbers
« Reply #26 on: August 21, 2015, 08:46:13 PM »
So try this:
      (foreach x charlst
         (if (member x test)
  4.                (chr x)
  5.                ""
  6.              )
  7.            )
  9.        )
  10.      )
  11. )
  12. (if str
  14.     (atof str)
  15.     ;; Boom
  16.     (read str)
  17.     ;; No Boom
  19.   )
  20. )
This seems to be a moving target. The title of the thread is "adding numbers". If you're parsing a number out of strings, adding a 0 in front and calling READ has no side effect other than avoiding your 'misplaced dot on input' error.
Try this:
(read "0.1")
(read "01000")
Re: Adding Numbers
« Reply #27 on: August 22, 2015, 06:46:59 AM »
But ".100" is not a valid number as far as AutoLISP is concerned.
Re: Adding Numbers
« Reply #28 on: August 22, 2015, 08:24:35 AM »
This is a very old lisp (2004+) that may be of some help.  Lee's parse number lisp is a good way to go.
cmwade77
Re: Adding Numbers
« Reply #29 on: August 24, 2015, 12:03:05 PM »
So try this:
      (foreach x charlst
         (if (member x test)
  4.                (chr x)
  5.                ""
  6.              )
  7.            )
  9.        )
  10.      )
  11. )
  12. (if str
  14.     (atof str)
  15.     ;; Boom
  16.     (read str)
  17.     ;; No Boom
  19.   )
  20. )
Try this:
(read "0.1")
(read "01000")
Not really, it's just this particular subfunction gets reused elsewhere and has specific requirments, otherwise your suggestion would work quite well.
