Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Place text where block (Multiple Block Selection)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Place text where block (Multiple Block Selection) (Read 2598 times)
sanju2323
Newt
on:
August 17, 2015, 04:06:04 AM »
Place text at block. I need lisp two type first layer wise and second block name wise place.
Last Edit: August 17, 2015, 11:07:57 AM by sanju2323
Logged
ChrisCarlson
Guest
Re: Place text where block (Multiple Block Selection)
Reply #1 on:
August 17, 2015, 10:42:39 AM »
Huh?
Logged
sanju2323
Newt
Reply #2 on:
August 17, 2015, 11:02:54 AM »
ChrisCarlson,
I don't understand what are you saying.
Logged
Needs a day job
Reply #3 on:
August 17, 2015, 11:07:20 AM »
Quote from: sanju2323 on August 17, 2015, 11:02:54 AM
ChrisCarlson,
You need a better example drawing of the results you are looking for. Chris is saying he does not understand your question & I don't either.
Logged
sanju2323
Newt
Reply #4 on:
August 17, 2015, 11:37:58 AM »
Please download sample2 file for a better understand.
Logged
ChrisCarlson
Guest
Reply #5 on:
August 17, 2015, 11:51:44 AM »
For block name, why not just edit the block and insert the name of the block as a text entity?
Logged
sanju2323
Newt
Reply #6 on:
August 17, 2015, 12:04:16 PM »
Sir, at this time the block name changes one by one to a long time procedure. I think lisp I would live to save my time.
Logged
ChrisCarlson
Guest
Reply #7 on:
August 17, 2015, 12:08:13 PM »
I can't write it at this time but look into the following
Code - Auto/Visual Lisp:
[Select]
setq
obj
vlax
ename
vla-object
car
entsel
layer
vla-get-layer
obj
point
vlax-get
obj 'InsertionPoint
and create a text entity from those variables.
Logged
Needs a day job
Reply #8 on:
August 17, 2015, 12:24:20 PM »
Here you go:
[Select]
defun
c:foo
_txt e n p ss
defun
_txt
p l s
entmakex
list
0
"TEXT"
100
"AcDbEntity"
67
0
cons
8
l
100
"AcDbText"
cons
10
p
40
2.0
cons
1
s
50
0.0
41
1.0
51
0.0
71
0
72
1
cons
11
p
73
2
if
setq
ss
ssget
0
"insert"
repeat
setq
n
sslength
ss
setq
e
ssname
ss
setq
n
1-
n
setq
p
cdr
assoc
10
entget
e
_txt p
"_LayerLabel"
cdr
assoc
8
entget
e
_txt p
"_BlockNameLabel"
cdr
assoc
2
entget
e
princ
Logged
sanju2323
Newt
Reply #9 on:
August 17, 2015, 12:28:36 PM »
Thanks both of you its work
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
