Author Topic: Possible to detect if current layer changed?  (Read 2490 times)
nobody
  • .net stuff
« on: August 16, 2015, 05:21:36 AM »
Is it possible to detect if the current layer changed? I'd like to update a form to show the current layer and want to make sure it stays correct.
huiz
  • Certified Prof C3D
Re: Possible to detect if current layer changed?
« Reply #1 on: August 16, 2015, 08:07:19 AM »
You can set an event handler for the system variable CLAYER.
nobody
  • .net stuff
« Reply #2 on: August 16, 2015, 04:25:30 PM »
For anyone else who might want to do this, below is how I accomplished it. I'm sure things are wrong with it but it works for now. Thanks Huiz for the advice.
Code - C#: [Select]
  1.        public void layerchangedmonitor()
  2.         {
  3.             acApp.SystemVariableChanged += new Autodesk.AutoCAD.ApplicationServices.SystemVariableChangedEventHandler(SysVariableChange);
  4.         }
  5.
  6.
  7.         void SysVariableChange(object sender, Autodesk.AutoCAD.ApplicationServices.SystemVariableChangedEventArgs e)
  8.         {
  9.             if (e.Name == "CLAYER")
  10.             {
  11.                 //do anything you want here. I got the current layer then updated a text box with its name and another with the color that matched its values.
  12.                 string currentWorkspaceName = (string)acApp.GetSystemVariable(e.Name);
  13.                 LayerTableRecord mylayer = MyCollectors.GetCurrentLayer();
  14.                 CurrentLayerBox.Text = mylayer.Name.ToString();
  15.                 CurrentLayerColorBox.BackColor = mylayer.Color.ColorValue;
  16.             }
  17.
  18.         }
« Last Edit: August 16, 2015, 04:37:53 PM by Alien »
BlackBox
« Reply #3 on: August 16, 2015, 07:03:02 PM »
Nothing to add to Henrique's apt post, however should you need to know more about Layer changes, you can use Bindable Object Layer (BOL), just mind the additional overhead:
http://through-the-interface.typepad.com/through_the_interface/2012/07/finding-out-about-changes-to-autocad-layers-via-the-bindable-object-layer-using-net.html
nobody
  • .net stuff
« Reply #4 on: August 17, 2015, 12:28:18 AM »
Thanks!
MexicanCustard
« Reply #5 on: August 17, 2015, 07:49:34 AM »
Not sure this method incurs much additional overhead.  AutoCAD is creating the observable collection whether you ever use it or not. Subscribing to its events is no more overhead than subscribing to Application.SystemVariableChanged.
BlackBox
« Reply #6 on: August 17, 2015, 02:49:18 PM »
Correct; it's not the event subscription that can consume more overhead.
It's the per-document storage of a given LayerTabelRecords's settings before a change, a subsequent store after changes, and the comparative functionality thereafter if needing to identify which LayerTableRecord Property(s) have been changed to what values (from what values?) that would require additional overhead - and again, only if such reporting is even needed.
