Author Topic: Revit Citrix  (Read 1101 times)
diarmuid
Revit Citrix
« on: August 07, 2015, 04:00:46 AM »
We are currently attempting to work on Revit projects in two offices simultaneously.  Both of these offices are in separate countries and we are investigating using Revit Citrix.  We are using Revit Server but the WAN speed is awful and it leads to model opening times of 2 hours.  Despite all our efforts.
So, i've been asked to investigate the possibility of using Revit via Citrix.
Has anyone had any experience of using Revit specifically over Citrix and what would your recommendations be?
How did you overcome the 3D hardware acceleration issue?  Did you use ZenDesktop? or other?
Was there any other additional hardware required.
Any help in this would be very much appreciated.
Regards
Diarmuid
If you want to win something run the 100m, if you want to experience something run a marathon
