Author Topic: Select Window?  (Read 2045 times)
craigr
Select Window?
« on: August 04, 2015, 08:14:04 AM »
While working away, a window or ??? came up and like a dummy, I figured 'hey, I wonder what this is'.  So, I made a couple of changes and now the attached pops up every time I select something.
I HAVE gone thru the Options / Select tab, but still can figure out how to turn this off.
Can any of you help me out?
Rob...
Re: Select Window?
« Reply #1 on: August 04, 2015, 08:24:19 AM »
That's "Selection Cycling". It's for choosing which overlapping object you want to select. Ctrl+W turns it off.
CAD Tech
craigr
Re: Select Window?
« Reply #2 on: August 04, 2015, 08:26:17 AM »
Thank You EVER so much!!!
I'm sure that it has its uses, but when not used to it......
craigr
Rob...
Re: Select Window?
« Reply #3 on: August 04, 2015, 08:37:05 AM »
I hear ya. I've recently been trying out "new" features that I turned off years ago because I didn't see any value and they usually popped up or took up screen space that I wanted. That is one that I decided to turn on. When you have a chance, check it out.
CAD Tech
huiz
  • Certified Prof C3D
Re: Select Window?
« Reply #4 on: August 04, 2015, 08:45:15 AM »
This is indeed a feature I really like and turned on here.
craigr
Re: Select Window?
« Reply #5 on: August 04, 2015, 08:54:27 AM »
The window just kept getting in the way.
Traditionally, IF by chance I select something that I don't want, I simply hold the shift key and click to remove what I don't want.
I just didn't see the need for the little window to pop up. - I guess it is just not what I am used to.
Re: Select Window?
« Reply #6 on: August 04, 2015, 08:55:18 AM »
It has it's place, however i could function much better; like telling you what layer or what xref the object(s) are part of.
tombu
  • ByLayer=>Not0
Re: Select Window?
« Reply #7 on: August 05, 2015, 02:11:02 PM »
From my acaddoc.lsp
(if (> (getvar 'selectioncycling) 0)(progn(setvar 'selectioncycling (- (getvar 'selectioncycling)))(princ "\nTurn \"selectioncycling\" off. SELECTIONCYCLING")))
(princ "\nTo Select Objects Close Together: Hover+Shift+Spacebar to Cycle then pick to select visable object.")
Drove me nuts when it was introduced, thankfully haven't seen it in years!
I know how to turn it on if I ever need it someday.
Tom Beauford P.S.M.
craigr
Re: Select Window?
« Reply #8 on: August 05, 2015, 02:12:27 PM »
From my acaddoc.lsp
What does that Lisp do?
Re: Select Window?
« Reply #9 on: August 05, 2015, 04:08:44 PM »
disables that selection cycling tool
Rob...
Re: Select Window?
« Reply #10 on: August 05, 2015, 04:57:08 PM »
...every time you open AutoCAD, whether it needs to or not.
If you ever want to check out selection cycling and decide you like it, you will have to remove that from the acaddoc.lsp file.
CAD Tech
cadtag
Re: Select Window?
« Reply #11 on: August 06, 2015, 12:50:06 PM »
From my acaddoc.lsp
In LT??? nothing.   :evillaugh:
