Here is the complete scenario. I am trying to compare a set of sheet drawings. The original sheet drawings I want to keep all the layer states (Layers Thaw, Freeze, On, Off) the same.
In the Xref base file that it is referencing I am going to change several colors. No new layer names.
I want to be able to reload the xref base into the sheet drawing while preserving the layers (on, off, thaw, freeze).
End goal is then to print them off on paper to compare the original colors with the revised colors.
Does the help?
