Author Topic: null string in list  (Read 10633 times)
Re: null string in list
« Reply #30 on: August 04, 2015, 12:24:38 PM »
Oh, I made it smaller!? This one only checks to see if all entries are the same though.
  1. (apply '= (mapcar 'ascii '("" "" "")))
A slight tweak would suit the task  :wink:
  1. (vl-every 'zerop (mapcar 'ascii '("" "" "")))
« Reply #31 on: August 04, 2015, 01:30:52 PM »
Another:
  1. (defun f4 ( l )
  2.     (not (while (= "" (car l)) (setq l (cdr l))))
  3. )
Marc'Antonio Alessi
  • Marco
« Reply #32 on: August 04, 2015, 04:32:35 PM »
slover:
(defun f5 (l) (if (= "" (car l)) (= "" (last (vl-sort l '=)))))
(setq alist '("" "" "" ""))
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Elapsed milliseconds / relative speed for 262144 iteration(s):
    (VL-REMOVE1 ALIST).....1719 / 1.29 <fastest>
    (VL-REMOVE1 ALIST).....1734 / 1.28
    (F4 ALIST).............1938 / 1.14
    (F4 ALIST).............1969 / 1.13
    (VL-EVERY12 ALIST).....2015 / 1.1
    (VL-EVERY12 ALIST).....2016 / 1.1
    (APPLY1 ALIST).........2047 / 1.08
    (F ALIST)..............2093 / 1.06
    (F ALIST)..............2125 / 1.04
    (F5 ALIST).............2125 / 1.04
    (APPLY3 ALIST).........2125 / 1.04
    (APPLY3 ALIST).........2141 / 1.04
    (APPLY2 ALIST).........2203 / 1.01
    (APPLY2 ALIST).........2219 / 1 <slowest>
    (VL-REMOVE1 ALIST).....1765 / 1.31 <fastest>
    (VL-REMOVE1 ALIST).....1766 / 1.31
    (F4 ALIST).............1969 / 1.17
    (VL-EVERY12 ALIST).....2031 / 1.14
    (F4 ALIST).............2046 / 1.13
    (VL-EVERY12 ALIST).....2047 / 1.13
    (APPLY1 ALIST).........2109 / 1.1
    (APPLY1 ALIST).........2110 / 1.1
    (F ALIST)..............2140 / 1.08
    (F5 ALIST).............2171 / 1.07
    (F ALIST)..............2188 / 1.06
    (F5 ALIST).............2188 / 1.06
    (APPLY3 ALIST).........2188 / 1.06
    (APPLY3 ALIST).........2203 / 1.05
    (APPLY2 ALIST).........2265 / 1.02
    (APPLY2 ALIST).........2313 / 1 <slowest>
Marc'Antonio Alessi
  • Marco
« Reply #33 on: August 04, 2015, 05:21:33 PM »
(defun f6 (l) (if (= "" (car l)) (not (while (vl-position "" (setq l (cdr l)))))))
    (VL-REMOVE1 ALIST2).....1703 / 1.29 <fastest>
    (F6 ALIST2).............1875 / 1.17
    (F4 ALIST2).............1953 / 1.13
    (VL-EVERY12 ALIST2).....1969 / 1.12
    (APPLY1 ALIST2).........2078 / 1.06
    (APPLY3 ALIST2).........2140 / 1.03
    (APPLY2 ALIST2).........2203 / 1 <slowest>
    (VL-REMOVE1 ALIST2)......1688 / 8.65 <fastest>
    (F6 ALIST2)..............1875 / 7.79
    (F4 ALIST2)..............1938 / 7.54
    (APPLY1 ALIST2)..........2031 / 7.19
    (APPLY2 ALIST2)..........2187 / 6.68
    (APPLY3 ALIST2).........12219 / 1.2
    (VL-EVERY12 ALIST2).....14609 / 1 <slowest>
Strange result on  VL-EVERY12 and APPLY3 on second test.
« Reply #34 on: August 04, 2015, 05:27:29 PM »
  1. _$ (f6 '("" "" "a"))
  2. T
Marc'Antonio Alessi
  • Marco
« Reply #35 on: August 04, 2015, 05:29:15 PM »
@Lee ok I take a look...
long list:
(setq alist2  alist)
(setq alist2 (repeat 200 (setq alist2 (append alist2 alist))))
Elapsed milliseconds / relative speed for 65536 iteration(s):
    (VL-REMOVE1 ALIST2)......1172 / 10.95 <fastest>
    (APPLY1 ALIST2)..........2328 / 5.51
    (VL-EVERY12 ALIST2)......4875 / 2.63
    (APPLY3 ALIST2)..........6094 / 2.11
    (APPLY2 ALIST2)..........6125 / 2.09
    (F6 ALIST2)..............8469 / 1.51
    (F4 ALIST2).............12828 / 1 <slowest>
    (VL-REMOVE1 ALIST2)......1031 / 11.77 <fastest>
    (APPLY1 ALIST2)..........2094 / 5.8
    (VL-EVERY12 ALIST2)......4907 / 2.47
    (APPLY2 ALIST2)..........6094 / 1.99
    (APPLY3 ALIST2)..........6203 / 1.96
    (F6 ALIST2)..............8188 / 1.48
    (F4 ALIST2).............12140 / 1 <slowest>
« Reply #36 on: August 04, 2015, 05:45:36 PM »
Don't think we've had this one yet:
  1. (defun f7 ( x ) (eval (vl-list* '= "" x)))
bruno_vdh
« Reply #37 on: August 04, 2015, 06:21:19 PM »
I have preferred him apply because eval evaluates arguments
_$ (setq A "")
_$ (= "" 'A 'A 'A)
nil
_$ (apply '= '("" A A A))
nil
_$ (eval  '(= "" A A A))
T
Regards,
Marc'Antonio Alessi
  • Marco
« Reply #38 on: August 05, 2015, 03:27:29 AM »
(defun f6 (l) ;F4 like
  (if (= "" (car l))
    (while (= "" (car (setq l (cdr l)))))
  (not l)
(setq alist2  alist)
(setq alist2 (repeat 20 (setq alist2 (append alist2 alist))))
Elapsed milliseconds / relative speed for 131072 iteration(s):
    (VL-REMOVE1 ALIST2).....1000 / 5.44 <fastest>
    (APPLY1 ALIST2).........1390 / 3.91
    (VL-EVERY12 ALIST2).....1875 / 2.9
    (APPLY3 ALIST2).........2093 / 2.6
    (APPLY2 ALIST2).........2157 / 2.52
    (F6 ALIST2).............3281 / 1.66
    (F4 ALIST2).............3406 / 1.6
    (F7 ALIST2).............5438 / 1 <slowest>
    (VL-REMOVE1 ALIST2).....1047 / 5.3 <fastest>
    (APPLY1 ALIST2).........1468 / 3.78
    (VL-EVERY12 ALIST2).....1907 / 2.91
    (APPLY3 ALIST2).........2250 / 2.47
    (APPLY2 ALIST2).........2281 / 2.43
    (F6 ALIST2).............3422 / 1.62
    (F4 ALIST2).............3438 / 1.61
    (F7 ALIST2).............5547 / 1 <slowest>
roy_043
  • BricsCAD 18
« Reply #39 on: August 05, 2015, 04:28:12 AM »
@ Marc'Antonio:
Your speed test is interesting but you only test with a list in which all elements are equal. If there is an alternate element halfway in the list the results will be quit different. For example, as bruno_vdh already hinted, solutions using (vl-every) will then perform relatively better.
bruno_vdh
« Reply #40 on: August 05, 2015, 06:17:26 AM »
Good explanation of roy_043, if one is maniac in comparisons, we can add a condition to apply and every for a nil argument  :wink:
(and lst (vl-every '= (cons "" lst) lst))
(and lst (apply '= (cons "" lst)))
For the game, one last less powerful variant with vl-member-if-not
(defun f (l)
   (if l
     (not (vl-member-if-not '(lambda (x) (eq "" x)) l))
Regards,
« Last Edit: August 05, 2015, 06:25:04 AM by bruno_vdh »
Marc'Antonio Alessi
  • Marco
« Reply #41 on: August 05, 2015, 08:37:30 AM »
Ok... new test:
(setq alist0 '(""  "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ""))
(setq alistS '("1" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ""))
(setq alistE '("" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "1"))
    (VL-REMOVE1 ALIST0).....1828 / 3.8 <fastest>
    (APPLY1 ALIST0).........2312 / 3.01
    (VL-EVERY12 ALIST0).....2625 / 2.65
    (APPLY3 ALIST0).........2782 / 2.5
    (APPLY2 ALIST0).........2875 / 2.42
    (F6 ALIST0).............3985 / 1.74
    (F4 ALIST0).............4078 / 1.71
    (F_VDH ALIST0)..........6719 / 1.03
    (F7 ALIST0).............6953 / 1 <slowest>
    (F4 ALISTS).............1657 / 4.04 <fastest>
    (F6 ALISTS).............1750 / 3.82
    (VL-REMOVE1 ALISTS).....1906 / 3.51
    (VL-EVERY12 ALISTS).....2000 / 3.34
    (APPLY1 ALISTS).........2047 / 3.27
    (APPLY2 ALISTS).........2953 / 2.26
    (APPLY3 ALISTS).........3125 / 2.14
    (F_VDH ALISTS)..........4672 / 1.43
    (F7 ALISTS).............6687 / 1 <slowest>
    (VL-REMOVE1 ALISTE).....1110 / 3.27 <fastest>
    (APPLY1 ALISTE).........1125 / 3.22
    (VL-EVERY12 ALISTE).....1313 / 2.76
    (APPLY2 ALISTE).........1750 / 2.07
    (APPLY3 ALISTE).........1765 / 2.05
    (F6 ALISTE).............1797 / 2.02
    (F4 ALISTE).............1969 / 1.84
    (F7 ALISTE).............3484 / 1.04
    (F_VDH ALISTE)..........3625 / 1 <slowest>
Marc'Antonio Alessi
  • Marco
« Reply #42 on: August 05, 2015, 08:47:59 AM »
Totals:
                     Total: 4844
                     Total: 5484
                     Total: 5938
                     Total: 7532
                     Total: 7578
                     Total: 7672
                     Total: 7704
                     Total:15016
                     Total:17124
bruno_vdh
« Reply #43 on: August 05, 2015, 09:49:52 AM »
@ Marc'Antonio Alessi, thanks these comparisons are interesting, but I find it hard to do ..
alist0 = alistE – 1  Performance comparison
And if alistS very long and it is more difficult for the vl-remove function
Regards,
PS: A list is infinite, how can we say that the list is long?
Marc'Antonio Alessi
  • Marco
« Reply #44 on: August 05, 2015, 01:17:28 PM »
Another:
  1. (defun f4 ( l )
  3. )
Comando: (f4 '("1" "" "" "" ""))
T
 :wink:
