Author Topic: null string in list  (Read 11672 times)
csgoh
Re: null string in list
« Reply #15 on: August 03, 2015, 11:08:25 PM »
Thank you all for the contribution.
cheers
77077
« Reply #16 on: August 04, 2015, 12:01:21 AM »
Lee ,can make it like this ?
'("" "" "") returns nil
'("1" "" "") returns nil
'("1" "10" "") returns nil
Only '("1" "s1"  "a") returns T
  1. _$ (defun f ( x ) (equal x '("1" "s1" "a")))
  2. _$ (f '("1" "s1" "a"))
  3. T
Thanks Lee,
77077
« Reply #17 on: August 04, 2015, 12:03:53 AM »
Another:
  1. (vl-every '= (cons "" lst) lst)
Very good roy.
Thanks.
@ ANJALI: If you want to check for the absence of empty strings you should try Keith's contribution. His code checks for the opposite, but that can easily be fixed...
Roy, Thank you. useful
Marc'Antonio Alessi
  • Marco
« Reply #18 on: August 04, 2015, 12:33:51 AM »
another:
(setq l '("" "" "" ""))
(eq (strlen (vl-princ-to-string l)) (1+ (length l)))
or
(and (eq "" (car l)) (equal l (acad_strlsort l)))
roy_043
  • BricsCAD 18
« Reply #19 on: August 04, 2015, 05:21:33 AM »
My variant
(apply '= (cons "" lst))
Nice! Very succinct and using 'Classic' Lisp only.
bruno_vdh
« Reply #20 on: August 04, 2015, 05:41:27 AM »
Yes, thank you
I'm surprised it is not written on TheSwamp
 = function alone is sufficient,
_$ (= "" "" "" "")
T
_$ (= "" 2 ABC T)
nil
Regards,
(Ps: roy_043, congratulation your solution with vl-every is very efficient)
« Last Edit: August 04, 2015, 05:48:03 AM by bruno_vdh »
« Reply #21 on: August 04, 2015, 08:35:39 AM »
Yes, thank you
_$ (= "" "" "" "")
T
_$ (= "" 2 ABC T)
nil
Regards,
But it is written on TheSwamp :-) You just added it ...
Incidentally,
_$ (= "a" "a" "a" "a")
T
bruno_vdh
« Reply #22 on: August 04, 2015, 09:36:09 AM »
Incidentally,
T
Sorry Keith, translator problem
I thought I explained why (apply '= (cons "" lst)), work in all cases
_$ (cons "" '("a" "a" "a" "a"))
("" "a" "a" "a" "a")
_$ (= "" "a" "a" "a" "a")
nil
Regards,
« Last Edit: August 04, 2015, 09:48:37 AM by bruno_vdh »
« Reply #23 on: August 04, 2015, 09:55:06 AM »
My first lisp in many years. Kinda fun (the code is kludgy but it was fun).
  1. (apply 'and (mapcar '(lambda (x) (eq (ascii x) 0)) '("" "" "")))
« Reply #24 on: August 04, 2015, 10:17:31 AM »
Oh, I made it smaller!? This one only checks to see if all entries are the same though.
  1. (apply '= (mapcar 'ascii '("" "" "")))
« Reply #25 on: August 04, 2015, 10:27:39 AM »
Hello,
I have say a list ("" "" "" "" "").
My variant
Regards,
That's nice.
Marc'Antonio Alessi
  • Marco
« Reply #26 on: August 04, 2015, 10:41:29 AM »
for maniacs...
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Elapsed milliseconds / relative speed for 262144 iteration(s):
    (VL-REMOVE1 ALIST).....2000 / 3.6 <fastest>
    (VL-EVERY12 ALIST).....2282 / 3.16
    (VL-EVERY12 ALIST).....2297 / 3.14
    (F ALIST)..............2375 / 3.03
    (F ALIST)..............2391 / 3.01
    (APPLY1 ALIST).........2547 / 2.83
    (APPLY1 ALIST).........2563 / 2.81
    (APPLY3 ALIST).........2672 / 2.7
    (APPLY2 ALIST).........2719 / 2.65
    (APPLY2 ALIST).........2734 / 2.63
    (F2 ALIST).............2922 / 2.47
    (F2 ALIST).............2938 / 2.45
    (APPLY6 ALIST).........3156 / 2.28
    (APPLY6 ALIST).........3172 / 2.27
    (APPLY4 ALIST).........3375 / 2.13
    (VL-SOME1 ALIST).......5516 / 1.31
    (VL-SOME1 ALIST).......5546 / 1.3
    (APPLY5 ALIST).........5656 / 1.27
    (APPLY5 ALIST).........5672 / 1.27
    (F3 ALIST).............6407 / 1.12
    (F3 ALIST).............6421 / 1.12
    (VL-EVERY1 ALIST)......7187 / 1
    (VL-EVERY1 ALIST)......7203 / 1 <slowest>
    (VL-REMOVE1 ALIST).....1860 / 3.72 <fastest>
    (VL-REMOVE1 ALIST).....1875 / 3.69
    (VL-EVERY12 ALIST).....2140 / 3.23
    (VL-EVERY12 ALIST).....2141 / 3.23
    (F ALIST)..............2250 / 3.08
    (APPLY1 ALIST).........2297 / 3.01
    (APPLY1 ALIST).........2313 / 2.99
    (APPLY3 ALIST).........2406 / 2.88
    (APPLY3 ALIST).........2422 / 2.86
    (APPLY2 ALIST).........2438 / 2.84
    (APPLY2 ALIST).........2469 / 2.8
    (F2 ALIST).............2750 / 2.52
    (F2 ALIST).............2765 / 2.5
    (APPLY6 ALIST).........2797 / 2.47
    (APPLY4 ALIST).........3000 / 2.31
    (APPLY4 ALIST).........3016 / 2.3
    (APPLY5 ALIST).........5218 / 1.33
    (APPLY5 ALIST).........5250 / 1.32
    (VL-SOME1 ALIST).......5265 / 1.31
    (VL-SOME1 ALIST).......5266 / 1.31
    (F3 ALIST).............6016 / 1.15
    (F3 ALIST).............6032 / 1.15
    (VL-EVERY1 ALIST)......6875 / 1.01
    (VL-EVERY1 ALIST)......6922 / 1 <slowest>
(defun apply1 (lst) (apply '= (cons "" lst)))
(defun vl-remove1 (lst) (not (vl-remove "" lst)))
(defun vl-every1 (l) (vl-every '(lambda (x) (and (= (type x) 'str) (= x ""))) l))
(defun apply2 (l) (zerop (strlen (apply 'strcat l))))
(defun apply3 (l) (= "" (apply 'strcat l)))
(defun apply4 (l) (zerop (apply '+ (mapcar 'strlen l))))
(defun vl-every12 (lst) (vl-every '= (cons "" lst) lst))
(defun vl-some1 (l) (not (vl-some '(lambda (u) (/= u "")) l)))
(defun f ( l ) (or (not l) (and (= "" (car l)) (f (cdr l)))))
(defun f2 (l) (eq (strlen (vl-princ-to-string l)) (1+ (length l))))
(defun f3 (l) (and (eq "" (car l)) (equal l (acad_strlsort l))))
(defun apply5 (l) (apply 'and (mapcar '(lambda (x) (eq (ascii x) 0)) l)))
(defun apply6 (l) (apply '= (mapcar 'ascii l)))
  :crazy2:
bruno_vdh
« Reply #27 on: August 04, 2015, 11:20:21 AM »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #28 on: August 04, 2015, 11:39:57 AM »
additional variant:
  1. (defun eea (l) (vl-every (function =) (cons "" l) l))
« Last Edit: August 04, 2015, 11:48:33 AM by ElpanovEvgeniy »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #29 on: August 04, 2015, 11:46:50 AM »
sorry this option is already there.  :-)
  1. (defun vl-every12 (lst) (vl-every '= (cons "" lst) lst))
