Author Topic: How to convert autocad object to binary string?  (Read 2760 times)
gswang
« on: August 02, 2015, 08:04:52 PM »
I want to convert autocad object to binary string, how can i do? thanks a lot!
nobody
  • .net stuff
Re: How to convert autocad object to binary string?
« Reply #1 on: August 03, 2015, 05:45:29 AM »
Hmmm...pretty general statement but once you get the object, assuming you just want to convert the name, you could do it like this:
http://stackoverflow.com/questions/5664345/string-to-binary-in-c-sharp
BlackBox
« Reply #2 on: August 03, 2015, 04:54:47 PM »
Wonder if OP means serializing to / deserializing from the Database?
« Reply #3 on: August 03, 2015, 08:11:48 PM »
Quote from: kdub
My argument has always been that we need to learn how to ask questions as much as we need to learn to solve problems.
« Reply #4 on: August 04, 2015, 11:30:14 AM »
Very much at the top of my list of recommended reads.
http://catb.org/~esr/faqs/smart-questions.html
EDIT:
Still a link in theSwamp's general guidelines too.
https://www.theswamp.org/index.php?topic=9202.0
