Before I tackled .Net and when first diving into Civil3d I was desperate to access objects using lisp. Just some of the remnants of the past, and likely lots of rookie mistakes, but they did the job
;;;;Streams surface elevations in the command line
(defun c:SEI ()
(setq obj (vlax-ename->vla-object (car (entsel "\nSurface:"))))
(while
(setq pt (cadr (grread t)))
(setq pt (trans pt 0 1))
(print
(vlax-invoke obj 'FindElevationAtXY (car pt) (cadr pt))
;;;add elevation tags along a feature line...use with a block that has two attributes...one for elevation...another for description
(defun c:flt ()
(command "undo" "begin")
(setq mydwgscale (getvar "dimscale"))
(setq suffix (getstring "\nSuffix?"))
(print "Select Featureline:")
(setq featureobj (vlax-ename->vla-object (car (entsel))))
(while (= 0 0)
(setq location (getpoint "\nPoint Along Feature Line:"))
(setq location (vlax-curve-getClosestPointToProjection featureobj location '(0 0 1)))
(setq param (vlax-curve-getParamAtPoint featureobj location))
(setq pointdata (vlax-curve-getPointAtParam featureobj param))
(setq xpt (car pointdata))
(setq ypt (cadr pointdata))
(setq xy (list xpt ypt))
(setq elev (caddr pointdata))
(setq elev (rtos elev 2 2))
(command "-insert" "ELV-TAG DYN" xy 30 "45.0" elev suffix)
(command "undo" "end")
(princ));;;
;;;used to draw polylines in a profile view using stations and elevations
(defun c:pstal ()
(princ "\nPress Return to draw line")
(setq ptlist nil)
(command "-layer" "n" "B-CONST" "S" "B-CONST" "C" "140" "" "")
(setq ent (entsel "\nSelect profile view:"))
(while
(setq sta (getreal "\nStation:"))
(setq elev (getreal "\nElevation:"))
(setq obj (vlax-ename->vla-object (car ent)))
(vlax-invoke-method obj 'FindXYAtStationAndElevation sta elev 'x 'y)
(setq pnt (list x y))
(setq ptlist (append ptlist (list pnt)))
(setq ptlen (length ptlist))
(if (= ptlen 1)
(command "line" pnt)
(command "line")(foreach pnt ptlist (command pnt))(command nil)
(princ));;;;
;;;;;use with a block with 2 attributes... your finish grade profile should be named exactly the same as your alignment with "-CL-FG" at the end. It inserts the block and places the elevation and station
;;;adds sta and elevation label to profile view
(defun c:pstl ()
(command "-layer" "n" "C-PROF-T" "S" "C-PROF-T" "C" "GREEN" "" "")
(while (= 0 0)
(setq proparent (vlax-get-property obj 'parent))
(setq nam (vlax-get-property proparent 'Name))
(setq pro (vlax-get-property proparent 'profiles))
(vlax-put (vlax-invoke-method pro 'item 0) 'name (strcat nam "-CL-FG"))
(setq pronam (vlax-invoke-method pro 'item (strcat nam "-CL-FG")))
(setq propvi (vlax-get-property pronam 'pvis))
(setq pnt (getpoint "\nPoint to Label:"))
(setq xpnt (car pnt))
(setq ypnt (cadr pnt))
(setq staoff (vlax-invoke-method obj 'FindStationAndElevationAtXY xpnt ypnt 'sta 'elev))
;;;covert to station;;;
(setq stat (rtos sta 2 2))
(setq stal (- (strlen stat) 1))
(if (= stal 6)
(setq lta (substr stat 1 2))
(setq ltb (substr stat 3 6))
(setq sta (strcat lta "+" ltb))
) ;end progn
;else
(if (= stal 5)
(setq lta (substr stat 1 1))
(setq ltb (substr stat 2 5))
) ;end progn
;else
(if (= stal 4)
(setq ltb (substr stat 2 4))
(setq sta (strcat "00+" lta ltb))
) ;end progn
;else
(if (= stal 3)
(setq ltb (substr stat 2 3))
(setq sta (strcat "00+0" lta ltb))
;;;end conversion;;;;
(command "-insert" "PROF-NOTE" pnt "40.0" "" "45.0" (strcat "STA.=" sta)(strcat "INV.=" elev)"")
(princ));;;;
;;;;adds pvi to profile view...profiles need to have exact name of alignment with "-CL-FG" at the end;;;;
(defun c:apvi ()
(while (= 0 0)
(setq pnt (getpoint "\nAdd PVI:"))
(vlax-invoke-method propvi 'add sta elev 1)
(setq pviat (vlax-invoke-method propvi 'itemat sta elev))
(setq pviin (vlax-get-property pviat 'gradein))
(setq pvigout (vlax-get-property pviat 'gradeout))
(princ));;;;
;;;;delete pvi from profile view...profiles need to have exact name of alignment with "-CL-FG" at the end;;;
(defun c:dpvi ()
(while (= 0 0)
(setq pnt (getpoint "\nDelete PVI:"))
(vlax-invoke-method propvi 'RemoveAt sta elev)
(princ));;;;
;;;;fgpoly creates multi-3dpoly at profile alignment....profile needs to be named exactly like alignment with "-CL-FG" at the end
(defun c:fgpm ()
(setq ptlist nil)
(setq adj (getreal "\nChange in Elevation:"))
(setq sel (entsel "\nSelect Alignment: "))
(setq inc 1)
(setq ent (car sel))
(setq obj (vlax-ename->vla-object ent))
(setq end (vlax-get obj 'EndingStation))
(setq nam (vlax-get-property obj 'Name))
(setq pro (vlax-get-property obj 'profiles))
(setq pviobj (vlax-get pronam 'pvis))
(setq countpvis (vlax-get-property pviobj 'count))
(setq lastpvis (- countpvis 1))
(setq firstpvi (vlax-invoke pviobj 'item 0))
(setq lastpvi (vlax-invoke pviobj 'item lastpvis))
(setq stapvi (vlax-get firstpvi 'Station))
(setq endpvi (vlax-get lastpvi 'Station))
(setq sta (+ stapvi 1.0))
(while (< sta endpvi)
(vlax-invoke-method obj 'PointLocation sta 0 'east 'north)
(vlax-invoke-method obj 'StationOffset east north 'sta 'off)
(setq elev (vlax-invoke-method pronam "ElevationAt" sta))
(setq datum (+ elev adj))
(setq elevfnl (atof (rtos datum 2 2)))
(setq points (list (atof (rtos east 2 2)) (atof (rtos north 2 2)) elevfnl))
(setq ptlist (append ptlist (list points)))
(vlax-invoke-method obj 'PointLocation sta 17 'east 'north)
(setq elevr (vlax-invoke-method pronam "ElevationAt" sta))
(setq datumr (+ elev adj))
(setq datumr (- datumr 0.34))
(setq elevfnlr (atof (rtos datumr 2 2)))
(setq pointsr (list (atof (rtos east 2 2)) (atof (rtos north 2 2)) elevfnlr))
(setq ptlistr (append ptlistr (list pointsr)))
(vlax-invoke-method obj 'PointLocation sta -17 'east 'north)
(setq elevl (vlax-invoke-method pronam "ElevationAt" sta))
(setq datuml (+ elev adj))
(setq datuml (- datuml 0.34))
(setq elevfnll (atof (rtos datuml 2 2)))
(setq pointsl (list (atof (rtos east 2 2)) (atof (rtos north 2 2)) elevfnll))
(setq ptlistl (append ptlistl (list pointsl)))s
(setq sta (+ sta inc))
(command "3dpoly")(foreach points ptlist (command points)"")(command nil)
(command "3dpoly")(foreach pointsr ptlistr (command pointsr)"")(command nil)
(command "3dpoly")(foreach pointsl ptlistl (command pointsl)"")(command nil)
(princ));;;;
;;;draw line on alignment by station;;;
(defun c:stal ()
(while (= 0 0)
(setq sta (getreal "\nStation: "))
(setq lst (entget ent))
(vlax-invoke-method obj 'PointLocation sta -100 'east 'north)
(setq start (strcat (rtos east 2 2) "," (rtos north 2 2)))
(vlax-invoke-method obj 'PointLocation sta 100 'east 'north)
(setq end (strcat (rtos east 2 2) "," (rtos north 2 2)))
(command "line" start end "")
(princ));;;;
;;;label station and offset;;;
(defun c:stl ()
(setq lst nil)
(while T
(setq pt1 (getpoint "\nPoint: "))
(setq rtpoint pt1)
(setq sta1 (vlax-get-property obj 'StartingStation))
(setq sta2 (vlax-get-property obj 'EndingStation))
(vlax-invoke-method obj 'StationOffset (car pt1) (cadr pt1) 'sta 'off)
(setq sta (rtos sta 2 2))
(setq off (rtos off 2 2))
;;;convert to station format;;;;
(setq sta2 (atof sta))
(setq x sta2)
(setq n 2)
(setq pref (fix (/ x 100.00)))
(setq suff (rtos (- x (* 100 pref)) 2 n))
(setq fnl (strcat (itoa pref) "+" suff))
;;;add left or right to offset;;;
(setq off2 (atof off))
(if (< off2 0)(setq side "' LT.")(setq side "' RT."))
(setq off (atof off))
(setq off (abs off))
(setq off (strcat off side))
(command "text" pt1 "" FNL)
(setq ent1 (entlast))
(command "text" "" off)
(setq ent2 (entlast))
(command "rotate" ent1 ent2 "" rtpoint pause)
);end while
(princ));;;
