Author Topic: if no choice the surface ,Can't continue until chose the face  (Read 5783 times)
andy_lee
Dear all
We know (vl-cmdf "_.UCS" "_F") is returns T , and  (command "_.UCS" "_F") is returns nil
I want know
when I use  (command "_.UCS" "_F") or   (vl-cmdf "_.UCS" "_F"),   if  no choice the surface ,Can't continue  until  chose the face.
Is there any way to do it?
andy.
Best regards.
77077
Re: if no choice the surface ,Can't continue until chose the face
« Reply #1 on: August 02, 2015, 06:25:00 AM »
I think no possible
mianbaoche
« Reply #2 on: August 02, 2015, 07:29:13 AM »
andy_lee Try!
  1. (defun c:tt()
  2.   (setq org (getvar "UCSORG"))
  3.   (vl-cmdf "_.UCS" "_F")
  4.   (while (null (equal 0 (distance (getvar "UCSORG" ) org) 1e-6))(vl-cmdf ""))
  5.  )
« Last Edit: August 02, 2015, 02:29:56 PM by mianbaoche »
andy_lee
« Reply #3 on: August 03, 2015, 04:24:03 AM »
andy_lee Try!
  1. (defun c:tt()
  5.  )
Hi mianbaoche
The trouble is still exist .  Can use Dxf or vla to solve?
andy.
Best regards.
mianbaoche
« Reply #4 on: August 03, 2015, 04:34:41 AM »
You can tell what the results,continue  until  to do?
To speak clearly and easily understand
Can use Dxf or vla to solve?Not very understanding。
77077
« Reply #5 on: August 03, 2015, 05:15:44 AM »
I said that is not possible.
OP's describe is very clearly.  if this is  possible, Lee , roy ,ron  has given the answer.
andy_lee
« Reply #6 on: August 03, 2015, 06:05:56 AM »
Ok, Thanks guys.  I abandoned. :oops:
andy.
Best regards.
« Reply #7 on: August 04, 2015, 12:48:29 AM »
andy_lee,
What is your goal ?
Do you require to set the UCS to a solid face without selecting the face ??
Do you have difficulty selecting/choosing the face ?
Are you unable to select the face for some reason ?
If you don't select the face, how do you imagine the UCS can be set ??
More explicit details of your requirements may help to find an answer.
added:
I have been watching this thread and noticed a lot of nasty behaviour which required deleted posts.
Please be a little nicer to each other ... we are ALL here to learn, not to play silly mean games.
« Last Edit: August 04, 2015, 01:21:23 AM by Kerry »
andy_lee
« Reply #8 on: August 04, 2015, 01:50:56 AM »
Hi Kerry
What happened?
sorry for my english .
  1.   (setq cmde (getvar 'cmdecho))
  2.   (setvar 'cmdecho 1)
  3.   (if e
  4.     (progn
  5.       (command "_.copybase" "_non" p e "" "")
  6.       (entdel e)
  7.       (prompt "\nPick face of 3D solid (edge which is parallel to Trapezoid top edge), then adjust UCS further more (Xflip, Yflip, next face if wrong picked) and then press ENTER to accept...")
  8.       (command "_.UCS" "_F")
  9.
;;if  no choice the surface ,Can't continue
  1.       (while (< 0 (getvar 'cmdactive)) (command "\\"))
  2.       (setq p (getpoint "\nPick or specify top center point to place Trapezoid : "))
  3.       (command "_.pasteclip" "_non" p)
  4.       (command "_.rotate" (entlast) "" "_non" p "\\")
  5.     )
  6.   )
  7.   (command "_.UCS" "_P")
  8.   (*error* nil)
  9.
The complete code from here:
Thanks marko.
http://www.theswamp.org/index.php?topic=49800.msg550233#msg550233
« Last Edit: August 04, 2015, 01:55:40 AM by andy_lee »
andy.
Best regards.
« Reply #9 on: August 04, 2015, 01:56:52 AM »
So, you have resolved the problem ??
andy_lee
« Reply #10 on: August 04, 2015, 01:58:47 AM »
No solution .
andy.
Best regards.
« Reply #11 on: August 04, 2015, 02:01:00 AM »
Please read my post again.
What is your actual problem  ???
andy_lee
« Reply #12 on: August 04, 2015, 02:04:29 AM »
 :cry: :cry: :cry:
http://www.theswamp.org/index.php?topic=49875.msg550678#msg550678
code...
I wrote explanatory notes here.
code...
andy.
Best regards.
« Reply #13 on: August 04, 2015, 02:09:00 AM »
 :cry: :cry: :cry:
code...
code...
What good is posting 'code' as an explanation for a problem if the code doesn't work.
I want you to read my post and answer the questions I asked.
andy_lee
« Reply #14 on: August 04, 2015, 02:48:41 AM »
 :cry: :cry: :cry:
code...
code...
Hi kerry
if use entsel function can like this :
(while (progn (null (setq e (entsel "\nPlease choose ."))))) ;; if no choose anything , can't continue or exit
as the same ,I need
when (command "_.UCS" "_F") , if no choose any face of 3d solid  ,can't run behind code
andy.
Best regards.
