using System;
using System.Collections;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.LayerManager;
namespace HpadCad.App
public class WblockBlocks : WblockStyleContainer
public WblockBlocks(BlockTable blockTbl)
foreach (var block in blockTbl.GetUserDefinedBlockTableRecords())
Add(block.Name, block.ObjectId);
protected override ObjectId ownerId
get { return HostApplicationServices.WorkingDatabase.BlockTableId;}
public class WblockTextStyles : WblockStyleContainer
public WblockTextStyles(TextStyleTable textStlyeTbl)
foreach (var textStlye in textStlyeTbl.GetTextStyleTableRecords())
Add(textStlye.Name, textStlye.ObjectId);
get { return HostApplicationServices.WorkingDatabase.TextStyleTableId; }
public class WblockDimStyles : WblockStyleContainer
public WblockDimStyles(DimStyleTable dimStlyeTbl)
foreach (var dimStlye in dimStlyeTbl.GetDimStyleTableRecords())
Add(dimStlye.Name, dimStlye.ObjectId);
get { return HostApplicationServices.WorkingDatabase.DimStyleTableId; }
public class WblockLineTypes : WblockStyleContainer
public WblockLineTypes(LinetypeTable lTypeTable)
foreach (var lType in lTypeTable.GetLinetypeTableRecords())
Add(lType.Name, lType.ObjectId);
get { return HostApplicationServices.WorkingDatabase.LinetypeTableId; }
public class WblockMleaderStyles : WblockStyleContainer
public WblockMleaderStyles(DBDictionary mleaderDictionay)
foreach (var entry in mleaderDictionay)
Add(entry.Key, entry.Value);
get { return HostApplicationServices.WorkingDatabase.MLeaderStyleDictionaryId; }
public class WblockLayers : WblockStyleContainer
public WblockLayers(LayerTable layerTbl)
foreach (var layerTableRecord in layerTbl.IncludingHidden.GetLayerTableRecords())
Add(layerTableRecord.Name, layerTableRecord.ObjectId);
public WblockLayers(IEnumerable<LayerTableRecord> layers , LayerFilter filter)
foreach (var layerTableRecord in layers)
if (filter.Filter(layerTableRecord))
get { return HostApplicationServices.WorkingDatabase.LayerTableId; }
public class StandardLayerFilters : IEnumerable<StandardLayerFilter>
List
> layerFilters
= new List
public StandardLayerFilters(Database db)
var layers = db.LayerTable().GetLayerTableRecords().ToList();
foreach (LayerFilter lf in db.LayerFilters.Root.NestedFilters)
if (!lf.AllowDelete) continue;
Add(new StandardLayerFilter
(layers, lf
public void Add(StandardLayerFilter item)
layerFilters.Add(item);
//public void Clear()
// throw new NotImplementedException();
//public bool Contains(StandardLayerFilter item)
//public void CopyTo(StandardLayerFilter[] array, int arrayIndex)
public int Count
get { return layerFilters.Count; }
public IEnumerator<StandardLayerFilter> GetEnumerator()
return layerFilters.GetEnumerator();
IEnumerator IEnumerable.GetEnumerator()
return GetEnumerator();
public string Name { get; set; }
public WblockLayers StandardLayers { get; set; }
public StandardLayerFilter(IEnumerable<LayerTableRecord> layers, LayerFilter filter)
Name = filter.Name;
StandardLayers
= new WblockLayers
(layers, filter
public IdMapping WblockCloneObjects()
ObjectIdCollection ids
= new ObjectIdCollection
(); foreach (var stdLayers in StandardLayers)
ids.Add(stdLayers.Value);
//LayerFilter df = null;
//foreach (LayerFilter lf in HostApplicationServices.WorkingDatabase.LayerFilters.Root.NestedFilters)
// if (!lf.AllowDelete) continue;
// if (String.Equals(lf.Name, Name, StringComparison.CurrentCultureIgnoreCase))
// df = lf;
IdMapping map
= new IdMapping
(); HostApplicationServices.WorkingDatabase.WblockCloneObjects(ids, HostApplicationServices.WorkingDatabase.LayerTableId, map, DuplicateRecordCloning.Ignore, false);
return map;
public class WblockBlockTableRecord : WblockContainer
public WblockBlockTableRecord(BlockTableRecord btr)
this.Add(btr.GetObjectIds());
get { return SymbolUtilityServices.GetBlockModelSpaceId(HostApplicationServices.WorkingDatabase); }
public abstract class WblockStyleContainer : IEnumerable<KeyValuePair<string, ObjectId>>
private Dictionary<string, ObjectId> dic;
protected abstract ObjectId ownerId { get;}
public WblockStyleContainer()
dic
= new Dictionary
<string, ObjectId
>(StringComparer
.OrdinalIgnoreCase); }
protected void Add(string key, ObjectId value)
dic.Add(key, value);
public bool Has(string key)
return dic.ContainsKey(key);
public ICollection<string> Keys
get { return dic.Keys; }
public bool TryGetValue(string key, out ObjectId value)
return dic.TryGetValue(key, out value);
public ICollection<ObjectId> Values
get { return dic.Values; }
public ObjectIdCollection IdsCollection
get
(); foreach (var objectId in dic)
ids.Add(objectId.Value);
return ids;
public ObjectId this[string key]
get { return dic[key]; }
protected set
dic[key] = value;
protected virtual ObjectId WblockCloneObject(string name, ObjectId ownerId, DuplicateRecordCloning dcr)
ObjectId id;
if (this.TryGetValue(name, out id))
(){id
}; IdMapping map
= new IdMapping
(); HostApplicationServices.WorkingDatabase.WblockCloneObjects(ids, ownerId, map, dcr, false);
return map[id].Value;
return ObjectId.Null;
protected virtual IdMapping WblockCloneObjects(IEnumerable<string> names, ObjectId ownerId, DuplicateRecordCloning dcr)
foreach (var name in names)
ObjectId id;
ids.Add(id);
IdMapping map
= new IdMapping
return map;
protected virtual IdMapping WblockCloneAllObjects(ObjectId ownerId, DuplicateRecordCloning dcr)
//var idArray = Ids;
//ObjectIdCollection ids = new ObjectIdCollection(idArray);
ObjectIdCollection ids = IdsCollection;
IdMapping map
= new IdMapping
return map;
public ObjectId WblockCloneObject(string name, DuplicateRecordCloning dcr = DuplicateRecordCloning.Ignore)
return WblockCloneObject(name, ownerId, dcr);
public IdMapping WblockCloneObjects(IEnumerable<string> names, DuplicateRecordCloning dcr = DuplicateRecordCloning.Ignore)
return WblockCloneObjects(names, ownerId, dcr);
public IdMapping WblockCloneAllObjects(DuplicateRecordCloning dcr = DuplicateRecordCloning.Ignore)
return WblockCloneAllObjects(ownerId,dcr );
public int Count
get { return dic.Count; }
public IEnumerator<KeyValuePair<string, ObjectId>> GetEnumerator()
return dic.GetEnumerator();
System.Collections.IEnumerator System.Collections.IEnumerable.GetEnumerator()
public abstract class WblockContainer : IEnumerable<ObjectId>
private List
<ObjectId
> ids
= new List
<ObjectId
>(); protected abstract ObjectId ownerId { get; }
public WblockContainer()
public void Add(ObjectId item)
ids.Add(item);
public void Add(IEnumerable<ObjectId> items)
foreach (var item in items)
ids.Add(item);
protected virtual IdMapping WblockCloneObjects(ObjectId ownerId, DuplicateRecordCloning dcr)
ObjectIdCollection idCollection
(ids
.ToArray());
IdMapping map
= new IdMapping
(); HostApplicationServices.WorkingDatabase.WblockCloneObjects(idCollection, ownerId, map, dcr, false);
return map;
public IdMapping WblockCloneObjects( DuplicateRecordCloning dcr = DuplicateRecordCloning.Ignore)
return WblockCloneObjects(ownerId, dcr);
public int Count
get { return ids.Count; }
public IEnumerator<ObjectId> GetEnumerator()
return ids.GetEnumerator();
public ObjectId this[int index]
get { return ids[index]; }
set { ids[index] = value; }
