A block with two attributes (or more) already has several inserts in the drawing. The same block was updated to have three attributes (or more) put the autoCAD only updates the block drawing and does not update the amount of attributes. There is a simple way of doing this update Autolisp in all blocks of the same name already in the design?
Attached a small example.
