It means someone has done this:
So should I do this?
Definitely not - and you would receive the same error if you did; you should instead try to ascertain the source of the problem.
On a brief inspection of the code for the
BLOCKTOXREF command, the issue seems to stem from the
acet-blocktoxref-copy-layer-props function defined on line 233 of the
blocktoxrefsup.lsp file: this function declares the symbol '
gc' as a local variable and uses this protected symbol within a
foreach loop.
I would suggest replacing all occurrences of the symbol '
gc' between lines 233 & 277 with say, '
gcc' (or any unprotected symbol which hasn't already been used).
