Author Topic: Command Line Switch Reference: "/pl"  (Read 1062 times)
Peter2
« on: July 28, 2015, 07:23:06 AM »
The switch "/pl" is described:
Quote from: Online help
Publishes a drawing set descriptions (DSD) file in the background. Use the following format:
<path><drawing set descriptions file>.DSD
Somebody here who uses or used it? I tried it - "Acad.exe" started as process, but not a Application, and does nothing. The DSD-file is OK, i could use it via dialogue.
Peter
BricsCAD V23
