Author Topic: Linetype display issues with converted DGN files.  (Read 1219 times)
Dave M
« on: July 27, 2015, 11:55:36 AM »
I have some DWG files that I exported from Microstation, and I am having issues with the correct display of the linetypes.  The linetype won't display correctly unless I override the linetype scale to match the viewport scales.  I am using architectural units, and default AutoCAD linetypes.  I have tried reloading the linetypes, but it doesn't make a difference.  I made a test DWG file, and set up multiple viewports at different scales, and the linetypes display as expected.
Anyone else ever have this problem?
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
HasanCAD
Re: Linetype display issues with converted DGN files.
« Reply #1 on: July 28, 2015, 02:48:40 AM »
In command line type LType
Then check this box
Dave M
« Reply #2 on: July 28, 2015, 11:19:28 AM »
Thanks for the reply, I am using that setting.
