if using C3D there is an option to create the profile left to right OR right to left....it's rare but the right to left method is useful sometimes
dview twist the viewports that the profile is showing....below themyou will need to reorient your labels however that should go rather quickly (if that is what the ground is doing?)
activate viewporttype DVIEW @ command lineselect an objectchose TWISTenter 180enter...you should be done...if your label blocks were set to match layout orientation you might not even need to rotate them
UCS World^C^C-view;top; UCS Right Elevation^C^Cdview;;tw;-90;;_ucs;w;_ucs;z;90; UCS Left^C^Cdview;;tw;90;;_ucs;w;_ucs;z;270; UCS Back^C^Cdview;;tw;180;;_ucs;w;_ucs;z;180;
Hi guys,Thank you very much for the help.But isn't working because if use dview and twist 180º I can't fix the labels.I don't know what to do.
Quote from: FABRICIO28 on July 27, 2015, 09:57:18 AMHi guys,Thank you very much for the help.But isn't working because if use dview and twist 180º I can't fix the labels.I don't know what to do. Set those label blocks to align to layout..I can't get that change to stick in block editor, so you may need to redefine the blocks and set that property from the beginning....Or re-label
