Author Topic: Viewport  (Read 5052 times)
Fabricio28
Viewport
« on: July 23, 2015, 10:13:44 AM »
Hi guys,
How are you?
How Can I mirror the viewport?
I'm working in a project and I need to mirror a viewport.
Anybody Can help me out please?
Regards
Re: Viewport
« Reply #1 on: July 23, 2015, 11:29:16 AM »
change the the 'view' in that viewport to BOTTOM if original is TOP
Left = Right
Front = Back
Actually it appears you want to either
Reverse your profile or
Use DVIEW>>TWIST>>180 on your viewports so that pipe flow direction matches your profile direction
Rob...
Re: Viewport
« Reply #2 on: July 23, 2015, 11:36:25 AM »
Why would you want to look at a "2D" drawing from the bottom?
Wouldn't mirroring the drawing be more appropriate?
CAD Tech
Fabricio28
Re: Viewport
« Reply #3 on: July 23, 2015, 02:30:02 PM »
Thank you for replay guys,
I wouldn't mirroring the drawing because the problem is the profile.
I have to start the profile in a highest point to a lower.
I've attached other file to explain better my task.
Thank in advance
Re: Viewport
« Reply #4 on: July 23, 2015, 02:33:31 PM »
if using C3D there is an option to create the profile left to right OR right to left....it's rare but the right to left method is useful sometimes
Fabricio28
Re: Viewport
« Reply #5 on: July 23, 2015, 03:01:16 PM »
Unfortunately I'm not using C3D.
How Can I fix it in autocad cad 2015?
Regards
Re: Viewport
« Reply #6 on: July 23, 2015, 03:08:07 PM »
dview twist the viewports that the profile is showing....below them
you will need to reorient your labels however that should go rather quickly (if that is what the ground is doing?)
Fabricio28
Re: Viewport
« Reply #7 on: July 23, 2015, 03:25:40 PM »
I don't know how to do that, to be honest.  :embarrassed:
Could you help me out, please?
Re: Viewport
« Reply #8 on: July 23, 2015, 03:31:32 PM »
activate viewport
type DVIEW @ command line
select an object
chose TWIST
enter 180
enter...
you should be done...if your label blocks were set to match layout orientation you might not even need to rotate them
Fabricio28
Re: Viewport
« Reply #9 on: July 23, 2015, 03:35:10 PM »
activate viewport
select an object
chose TWIST
enter 180
enter...
If I rotate the viewport, model space will change too?
Re: Viewport
« Reply #10 on: July 23, 2015, 04:50:10 PM »
you are not rotating the viewport...
you are twisting (rotating) what you see inside the viewport
your viewport...first as you posted
second twisted 180
Re: Viewport
« Reply #11 on: July 24, 2015, 10:10:31 AM »
I use these in buttons to work in Model Space.
They also work if you Open a Viewport.
UCS World
^C^C-view;top;
UCS Right Elevation
^C^Cdview;;tw;-90;;_ucs;w;_ucs;z;90;
UCS Left
^C^Cdview;;tw;90;;_ucs;w;_ucs;z;270;
UCS Back
^C^Cdview;;tw;180;;_ucs;w;_ucs;z;180;
Fabricio28
Re: Viewport
« Reply #12 on: July 27, 2015, 09:57:18 AM »
Hi guys,
Thank you very much for the help.
But isn't working because if use dview and twist 180º I can't fix the labels.
I don't know what to do.    :embarrassed2:
Re: Viewport
« Reply #13 on: July 27, 2015, 10:08:27 AM »
Hi guys,
Set those label blocks to align to layout..
I can't get that change to stick in block editor, so you may need to redefine the blocks and set that property from the beginning....
Or re-label
« Last Edit: July 27, 2015, 10:16:12 AM by mjfarrell »
Fabricio28
Re: Viewport
« Reply #14 on: July 27, 2015, 10:30:45 AM »
Hi guys,
Or re-label
Hi mjfarrell
I don't know how to set the labels to align to layout.
Could you make a little example in dwg file, please?
