Author Topic: Auto Fillet  (Read 6809 times)
BKT
Re: Auto Fillet
« Reply #15 on: July 25, 2015, 12:01:51 PM »
Try this:
(defun c:test ()
(if (= rad1 nil)
      (setq rad1 (getreal "\n Enter Fillet Radius: "))
      (setvar "filletrad" rad1)
(command "._pline")
    (while (= 1 (logand 1 (getvar "CMDACTIVE"))) (command pause))
    (command "._fillet" "_P" (entlast)
You should only need to enter the radius once for each session.
