Author Topic: Coordinates compertion  (Read 10404 times)
Shay Gaghe
Re: Coordinates compertion
« Reply #15 on: July 28, 2015, 08:44:33 AM »
Here's a simple way to approach it:
  1. (defun foo ( lst / key rtn )
  2.     (setq key (caar lst)
  3.           rtn (caadar lst)
  4.     )
  5.     (foreach grp lst
  6.         (foreach pnt (cadr grp)
  7.             (if (< (cadr rtn) (cadr pnt))
  8.                 (setq rtn pnt
  9.                       key (car grp)
  10.                 )
  11.             )
  12.         )
  13.     )
  14.     (list key rtn)
  15. )
  1. (setq lst
  2.    '(
  3.         ("a" ((0 2 4) (0 7 0) (0 2 0)))
  4.         ("b" ((0 2 0) (0 5 0) (0 2 0)))
  5.         ("c" ((3 2 0) (0 2 0) (9 3 0)))
  6.     )
  7. )
  1. _$ (foo lst)
  2. ("a" (0 7 0))
          rtn (caadar lst)
    (foreach grp lst
                (setq rtn pnt
                      key (car grp)
    (list key rtn)
;_rtn is the first point to be compared to
;_compare each delivered point's Y to rtn's Y
;_if the delivered point is bigger
;_replace  rtn with that point
;_replace the key with the delivered key
        ;_
;_
i understand it, but i dont know how i would explain it to someone else....what logical steps i need to plan in order  to the solution?
« Reply #16 on: July 28, 2015, 08:48:53 AM »
i need to learn what you did. :-o
thanks for the meantime....
You're welcome.
The task could be accomplished in many ways - here is another:
  1. (defun foo2 ( lst )
  2.     (car (vl-sort (apply 'append (mapcar '(lambda ( x ) (mapcar '(lambda ( y ) (list (car x) y)) (cadr x))) lst)) '(lambda ( a b ) (> (cadadr a) (cadadr b)))))
  3. )
  1. _$ (foo2 lst)
  2. ("a" (0 7 0))
Shay Gaghe
« Reply #17 on: July 28, 2015, 08:50:47 AM »
« Reply #18 on: July 28, 2015, 08:54:01 AM »
        ;_
;_
Your understanding looks to be correct.
Shay Gaghe
« Reply #19 on: July 28, 2015, 08:55:33 AM »
        ;_
;_
how do you map this logic to human language?  :-)
« Reply #20 on: July 28, 2015, 09:09:11 AM »
I don't see the point of your question - you have already described each step of the algorithm in 'human language', which shows that you already understand the algorithm; why then would you need this to be written in such a way to explain to someone else? Is this for a homework assignment?
Shay Gaghe
« Reply #21 on: July 28, 2015, 09:22:34 AM »
i spent half day thinking about this while you just solve it like you are sms "good morning" to your girlfriend  :-D :-D :-D
i just preparing myself to help my daughter with her homework :-D
I was always thinking there was  a way to tell the machine what to do as it was your employee, but I cant really see it possible, (otherwise there wasnt a need for programing language i guess).
I do understand the algorithm, and you understand that I understand it because you are a programmer, but if youwarnt  a programmer you wouldn’t understand.
irneb
« Reply #22 on: July 28, 2015, 09:27:59 AM »
how do you map this logic to human language?  :)
You mean something like this:
  • Keep track of the first point and its key in some local variables.
  • Look at each key+point pair in turn, comparing its Y value to the one in that local variable.
  • If the current point's Y is larger than the Y in the local variable, replace the contents of the local variables with the current point and its key.
  • Once all points have finished being compared, the local variables should now contain the values of the largest point, so return them as the last statement in the function.
That's still just a pipe dream ... one that was thought up in the 50s - 60s: What's referred to as a 4th generation programming language, i.e. a natural human language. 3rd being the normal programming languages we use mostly (e.g. Lisp / C / Python / etc.), 2nd being assembly code (i.e. CPU instructions as abreviated words), 1st being the 1s and 0s representing the on/off signals the CPU actually receives and sends.
Unfortunately human languages are very complex with lots of ambiguity, not the best thing for a computer to "understand". For these to actually work, you'd need a computer with "true" artificial intelligence, i.e. it would need to "understand" your meaning instead of just following a set of steps.
Shay Gaghe
« Reply #23 on: July 28, 2015, 09:35:15 AM »
yaa.. that why a robot can never replace a humen... lets cheers for that  :angel:
roy_043
  • BricsCAD 18
« Reply #24 on: July 28, 2015, 10:04:38 AM »
Another sort solution:
  1. ; (testSort2 lst)
  2. (defun testSort2 (lst / tmp)
  3.   (setq tmp
  4.     (vl-sort
  5.       (mapcar
  6.         '(lambda (sub)
  7.           (list
  8.             (car sub)
  9.             (vl-sort
  10.               (cadr sub)
  11.               '(lambda (a b) (> (cadr a) (cadr b)))
  12.             )
  13.           )
  14.         )
  15.         lst
  16.       )
  17.       '(lambda (a b) (> (cadr (caadr a)) (cadr (caadr b))))
  18.     )
  19.   )
  20.   (list (caar tmp) (caadar tmp))
  21. )
Recursive solution:
  1. ; (TestRecursive lst nil nil)
  2. (defun TestRecursive (lst key pt)
  3.   (cond
  4.     ((not lst)
  5.       (list key pt)
  6.     )
  7.     ;; No more points in sub:
  8.     ((not (cadar lst))
  9.       (TestRecursive (cdr lst) key pt)
  10.     )
  11.     ;; Check if current point has higher Y:
  12.     (
  13.       (>
  14.         (cadr (caadar lst))
  15.         (cadr pt)
  16.       )
  17.       (TestRecursive
  18.         (cons
  19.           (list (caar lst) (cdadar lst)) ; Remove point from current sub.
  20.           (cdr lst)
  21.         )
  22.         (caar lst)
  23.         (caadar lst)
  24.       )
  25.     )
  26.     (T
  27.       (TestRecursive
  28.         (cons
  29.           (list (caar lst) (cdadar lst))
  30.           (cdr lst)
  31.         )
  32.         key
  33.         pt
  34.       )
  35.     )
  36.   )
  37. )
irneb
« Reply #25 on: July 28, 2015, 11:51:48 AM »
Actually I would tend to go about it in a functional way - i.e. I'd want a reduce function (but AutoLisp doesn't have such built in). Thus I'd make one for myself. Here's a simplistic (imperative) variant which works in pretty much the same way as Lee's original code:
  1. (defun reduce (operation lst / accumulator)
  2.   (setq accumulator (car lst) operation (eval operation))
  3.   (foreach item (cdr lst)
  4.     (setq accumulator (operation accumulator item)))
  5.   accumulator)
Then I could use that by applying a custom operation onto it - the operation only ever needs to compare two inputs and return whichever it deems the "correct" or some modified value (e.g. when summing a list). In this example case you're looking for the highest Y value inside a list of points. So:
  1. (defun PointMaxY (pt1 pt2)
  2.   (if (> (cadr pt2) (cadr pt1)) pt2 pt1))
  3.
  4. ; Test code
  5. _$ (reduce 'PointMaxY '((1 2 3) (4 3 2) (2 0 6)))
  6. (4 3 2)
Of course, that's just half the issue in your OP. And that's where the map+reduce gives the power behind all this. E.g. extracting the "highest" point from each item in the keyed list:
  1. _$ (setq lst '(
  2.         ("a" ((0 2 4) (0 7 0) (0 2 0)))
  3.         ("b" ((0 2 0) (0 5 0) (0 2 0)))
  4.         ("c" ((3 2 0) (0 2 0) (9 3 0)))))
  5. (("a" ((0 2 4) (0 7 0) (0 2 0))) ("b" ((0 2 0) (0 5 0) (0 2 0))) ("c" ((3 2 0) (0 2 0) (9 3 0))))
  6. _$ (mapcar '(lambda (item) (list (car item) (reduce 'PointMaxY (cadr item)))) lst)
  7. (("a" (0 7 0)) ("b" (0 5 0)) ("c" (9 3 0)))
And then to extract the highest of each, another reduce on top of that:
  1. (reduce '(lambda (item1 item2)
  2.            (if (> (cadadr item2) (cadadr item1)) item2 item1))
  3.         (mapcar '(lambda (item)
  4.                    (list (car item) (reduce 'PointMaxY (cadr item))))
  5.                 lst))
  6. ("a" (0 7 0))
« Reply #26 on: July 28, 2015, 01:37:30 PM »
Good generalisation Irné  :-)
For fun, here's another recursive solution, hampered slightly by the data format:
  1. (defun foo ( lst )
  2.     (   (lambda ( bar ) (bar (apply 'append (mapcar '(lambda ( x ) (mapcar '(lambda ( y ) (list (car x) y)) (cadr x))) lst))))
  3.         (lambda ( lst )
  4.             (if (cdr lst)
  5.                 (if (< (car (cdadar lst)) (cadr (cadadr lst)))
  6.                     (bar (cdr lst))
  7.                     (bar (cons (car lst) (cddr lst)))
  8.                 )
  9.                 (car lst)
  10.             )
  11.         )
  12.     )
  13. )
(EDIT: Updated as per Roy's suggestion below)
« Last Edit: July 29, 2015, 05:15:33 AM by Lee Mac »
roy_043
  • BricsCAD 18
« Reply #27 on: July 28, 2015, 03:43:11 PM »
@ Lee: take another look at line 6 of the code in your last post:
(cons (cadr lst) (cddr lst)) :-o
« Reply #28 on: July 28, 2015, 03:47:20 PM »
Sorry roy, I don't follow?  :?
roy_043
  • BricsCAD 18
« Reply #29 on: July 29, 2015, 02:56:12 AM »
(setq lst '(0 1 2 3 4))
(cons (cadr lst) (cddr lst)) => (1 2 3 4)
(cdr lst) => (1 2 3 4)
