Author Topic: Coordinates compertion  (Read 10400 times)
Shay Gaghe
« on: July 22, 2015, 11:12:48 PM »
hi
i would ask if 2 points are equal like this
(defun isCordEqual (pa pb)
    (vl-every '= pa pb)
how can i ask if pa is smaller or equal to pb?
Shay
Re: Coordinates compertion
« Reply #1 on: July 22, 2015, 11:16:30 PM »
What do you mean by 'smaller than' for 3d points ???
« Reply #2 on: July 22, 2015, 11:49:27 PM »
While we are waiting:
by definition :
if each element of 'a is less than or equal to the elements of 'b
then
each element of 'b is greater than each element of 'a.
AND
if each element of 'a is more than or equal to the elements of 'b
then
each element of 'b is less than each element of 'a.
irneb
« Reply #3 on: July 23, 2015, 02:22:43 AM »
Simplistically ... just from the wording in the OP, use '<= (i.e. less than or equal to) instead of '=.
You'd need to figure out which of the 3 dimensions are the more influential during a sort, that's up to you (i.e. what would you want - levels different, then perhaps Z values). Then that defines the greater/less than check, if it's equal then the next one in line does the same. E.g. if you first check X, then Y then Z ... then a simple change to <= in your function would suffice. But what if you want higher / lower levels for Z to be the main defining one?
To show why you need to choose the first to check: Another less useful idea could be to create a comparison function. Note a comparison function for sorting basically returns 0 (if equal), -1 (if less than) and 1 (if greater than). Then add those numbers together by comparing each dimension in the 2 points, checking the result for > 0 or < 0 or = 0. Something like this:
  1. (defun comp-val (n m)
  2.   (cond ((< n m) -1)
  3.    ((> n m) 1)
  4.    (0)))
  5.
  6. (defun comp-lst (n m)
  7.   (apply '+ (mapcar 'comp-val n m)))
  8.
  9. (comp-lst '(1 2 3) '(2 1 3)) ; Returns 0 as none of XYZ is assumed more influential
If that returns 0, they're "equal", even when they're not. Thus even if that returns a negative (i.e. less than) or a positive (greater than), what does it actually mean?
BTW, with coordinates you have double floating point values. It's highly unlikely that any 2 double floats are equal. So the = function isn't a very good idea for equality testing in this case. I'd advise going with the equal function instead with a fuzz factor to accommodate floating errors. That fuzz factor depends on the scale of the values - since a double float is close to a 13 to 16 digit decimal accuracy. That means if the scale of the number is in the 10000 range, the accuracy is within 13 to 16 less the already taken up 5 digits - i.e. 8 to 11 decimal places after the point. Therefore the fuzz factor should be adjusted depending on the values being checked. Usually you just use the 8 decimal places to catch most problems by doing this:
  1. (equal n m 1e-8)
« Reply #4 on: July 23, 2015, 05:00:04 AM »
Smaller as in closer to the origin?
(< (distance '(0 0 0) a) (distance '(0 0 0) b))
David Bethel
« Reply #5 on: July 24, 2015, 11:33:31 AM »
Maybe :
  1.   (setq l1 '(1.001 0.999 1.0)
  2.         l2 '(1     1     1)
  3.         fz 1e-8)
  4.
  5.   (setq s "(")
  6.   (foreach a '(0 1 2)
  7.     (setq s (cond ((equal (nth a l1) (nth a l2) fz)
  8.                    (strcat s " = "))
  9.                   ((> (nth a l1) (nth a l2))
  10.                    (strcat s " > "))
  11.                   ((< (nth a l1) (nth a l2))
  12.                    (strcat s " < ")))))
  13.   (setq s (strcat s ")"))
  14.   (alert s)
-David
R12 Dos - A2K
Shay Gaghe
« Reply #6 on: July 27, 2015, 05:35:05 PM »
lets say i have this association list where every key refers a list. i want to know which list (a,b or c) has the highest/lowest point and the actual point.how can i do it?
(setq lst (list
    (cons "a"  (list '( (0 2 4) (0 7 0) (4 2 0))))
    (cons "b"  (list '( (8 2 0) (0 5 0) (7 7 0))))
    (cons "c"  (list '( (3 2 0) (0 2 0) (9 3 0))))
« Reply #7 on: July 27, 2015, 06:22:01 PM »
Highest meaning largest y-coordinate value?
Largest z-coordinate value?
Furthest from the origin?
« Reply #8 on: July 27, 2015, 06:35:49 PM »
It is a little tedious talking to myself.
Shay Gaghe
« Reply #9 on: July 27, 2015, 11:10:42 PM »
 :police: sorry. weekends are "full scan mode" for me  :police:
Shay Gaghe
« Reply #10 on: July 27, 2015, 11:20:55 PM »
by highest i meant the coordinate with the largest y value
in ("a" ((0 2 0) (0 7 0) (0 2 0))) the highest level is (0 7 0)
in ("b" ((0 2 0) (0 5 0) (0 2 0))) the highest level is (0 5 0)
in ("c" ((3 2 0) (0 2 0) (9 3 0))) the highest level is (9 3 0)
the highest level of all is (0 7 0) and the key is "a"
« Reply #11 on: July 28, 2015, 05:38:57 AM »
So, do you now want the cons-key, and the point ??
... or just the point ?
added:
and there may be any quantum of consed lists
and there may be any quantum of point lists in each consed list.
« Last Edit: July 28, 2015, 05:42:14 AM by Kerry »
Shay Gaghe
« Reply #12 on: July 28, 2015, 05:41:20 AM »
Both
« Reply #13 on: July 28, 2015, 05:44:08 AM »
Here's a simple way to approach it:
  1. (defun foo ( lst / key rtn )
  2.     (setq key (caar lst)
  3.           rtn (caadar lst)
  4.     )
  5.     (foreach grp lst
  6.         (foreach pnt (cadr grp)
  7.             (if (< (cadr rtn) (cadr pnt))
  8.                 (setq rtn pnt
  9.                       key (car grp)
  10.                 )
  11.             )
  12.         )
  13.     )
  14.     (list key rtn)
  15. )
  1. (setq lst
  2.    '(
  3.         ("a" ((0 2 4) (0 7 0) (0 2 0)))
  4.         ("b" ((0 2 0) (0 5 0) (0 2 0)))
  5.         ("c" ((3 2 0) (0 2 0) (9 3 0)))
  6.     )
  7. )
  1. _$ (foo lst)
  2. ("a" (0 7 0))
Shay Gaghe
« Reply #14 on: July 28, 2015, 06:56:29 AM »
  3.           rtn (caadar lst)
  4.     )
  5.     (foreach grp lst
  8.                 (setq rtn pnt
  9.                       key (car grp)
  10.                 )
  11.             )
  12.         )
  13.     )
  14.     (list key rtn)
  15. )
  1. (setq lst
  2.    '(
  6.     )
  7. )
  1. _$ (foo lst)
  2. ("a" (0 7 0))
i need to learn what you did. :-o
thanks for the meantime....
