Author Topic: File Associations  (Read 2038 times)
ChrisCarlson
File Associations
« on: July 22, 2015, 03:51:03 PM »
Is there a quick / painless way to reassociate all of AutoDesk's file extension to their applicable program?
eg; .dwg, .dst, .dwt, .pc3, .lsp, etc.
Re: File Associations
« Reply #1 on: July 22, 2015, 04:13:31 PM »
Set your default programs
Open Default Programs by clicking the Start button , and then clicking Default Programs.
Click Associate a file type or protocol with a program.
Click the file type or protocol that you want the program to act as the default for.
Click Change program.
« Reply #2 on: July 22, 2015, 05:16:54 PM »
Or you could try running a repair.
ChrisCarlson
« Reply #3 on: July 23, 2015, 08:11:03 AM »
Repair was a no-go, attempting a reinstall next.
« Reply #4 on: July 23, 2015, 08:37:12 AM »
And this did not work?
ChrisCarlson
« Reply #5 on: July 23, 2015, 11:31:51 AM »
No because AutoCAD does not simply use acad.exe as the target.
DWG launcher is used for .dwg, I haven't found how .dst, .pc3, .dwt etc opens.
« Reply #6 on: July 23, 2015, 11:39:59 AM »
Did not test this but maybe?
"C:\Program Files\Autodesk\AutoCAD 2016\AdMigrator.exe" /reset /product ACAD /language "en-US"
« Reply #7 on: July 23, 2015, 11:55:04 AM »
DST  = Sheet Set Manager
pc3 = Plotter configuration
DWT = Drawing Templte, i.e. Autocad.exe
Why not just Associate DWG and leave it at that?
I never open sheet sets without using the Sheet Set interface
Same for PC3's
What are your really attempting to do?
ChrisCarlson
« Reply #8 on: July 23, 2015, 12:53:39 PM »
Just fix a botched installation without removing and reinstalling (so far repair and reinstall through AutoCAD hasn't worked), having a file with the default "no icon" icon and no program to open it up is a teensy bit annoying.
Attempting to open a .dst with the target as acad.exe throws an error as an unknown drawing type.
I'd assume this is the same process as going through Add / Remove Programs and resetting AutoCAD from there.
