Author Topic: Reset a Viewport?  (Read 1384 times)
MSTG007
Reset a Viewport?
« on: July 22, 2015, 09:31:40 AM »
What is the quickest way to reset a viewport? Right now I am unlocking the viewport, setting it to a different scale, then setting it back to the original scale finally locking the viewport. The way we are setup it seems that if you go to one of the base files and change the annotation scale of text or something, save it, then reload it back into the sheet file it does not take it immediately on some; (others its file). So I have to do the above process to get it to show correctly.
Civil3D 2020
Re: Reset a Viewport?
« Reply #1 on: July 22, 2015, 09:35:23 AM »
REGENALL?
« Reply #2 on: July 22, 2015, 09:46:36 AM »
sometimes even UCSFOLLOW settings can play around with you...
also the toggle  show hide/ all anno scales can get things right
MSTG007
« Reply #3 on: July 22, 2015, 09:51:24 AM »
I try to do a REA all the time. I have messed around with the canno options. again sometimes it works other times it does not. The above is the only sure way that can fix the problem.
Civil3D 2020
« Reply #4 on: July 22, 2015, 02:46:09 PM »
I wonder
IF
you unlock the viewport BEFORE you reload that altered XREF or Data shortcut
does the symptom remain?
MSTG007
« Reply #5 on: July 23, 2015, 07:09:01 AM »
I did what you mentioned above and I get the same results. I did audit all files as well, with no errors. weird.
Civil3D 2020
