Author Topic: Change Fillet Radii more quickly  (Read 9410 times)
MSTG007
« on: July 21, 2015, 07:58:55 AM »
Is there a quick way to change fillet radius rather than going through the command progression of (fillet;Radius;number)?
I did not know if there way a command that could be (f20; which would make it a fillet of 20; or f4.5; which would make the fillet 4.5.
Just curious as usual. Thanks
Civil3D 2020
ChrisCarlson
Re: Change Fillet Radii more quickly
« Reply #1 on: July 21, 2015, 08:00:57 AM »
There was a tip in the wayback machine
http://cadtips.cadalyst.com/content/dynamic-fillet
« Reply #2 on: July 21, 2015, 08:34:26 AM »
one could put several 'fillets' on a tool palette
or investigate snap increment for alignment curves;  if that is what you are working with in C3D
huiz
  • Certified Prof C3D
« Reply #3 on: July 21, 2015, 08:44:43 AM »
Cool tip! I work with Civil3D for 8 years and didn't know of that  :?
Rob...
« Reply #4 on: July 21, 2015, 08:49:42 AM »
I don't see where the OP mentioned C3D. I guess you guys know something that is not apparent here.
CAD Tech
tedg
« Reply #5 on: July 21, 2015, 09:13:22 AM »
If you're into using lisp, some simple examples:
The command could be F20 and you fillet two lines with a 20 radius:
;;fillets 2 lines at "20" radius
(defun c:f20 ()
        (setq fr (getvar "filletrad"))
        (setq ob1 (entsel))
        (setq ob2 (entsel))
        (setvar "filletrad" 20)
        (command ".fillet" ob1 ob2)
        (setvar "filletrad" fr)(princ))
Or one I use allot which is just a lisp version of the command string you're trying to avoid.
You type "FR" and then the radius you want and select your lines.
;;fillet command that askes for radius first
(defun c:fr ()
(command ".fillet" "r" pause "" ".fillet")(princ)
These are basic but they work great...
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
MSTG007
« Reply #6 on: July 21, 2015, 10:59:24 AM »
Now we are talking! Thank you!
Civil3D 2020
« Reply #7 on: July 21, 2015, 12:26:22 PM »
The following will create custom commands for every radius listed (4.5, 10, 20, 30 etc.):
  1. (   (lambda nil
  2.         (foreach rad '(4.5 10 20 30)
  3.             (eval
  4.                 (list 'defun
  5.                     (read (strcat "c:f" (vl-string-translate "." "-" (vl-princ-to-string rad))))
  6.                    '( / fil )
  7.                    '(setq fil (getvar 'filletrad))
  8.                     (list 'setvar ''filletrad rad)
  9.                    '(vl-cmdf "_.fillet")
  10.                    '(while (< 0 (getvar 'cmdactive)) (vl-cmdf "\\"))
  11.                    '(setvar 'filletrad fil)
  12.                    '(princ)
  13.                 )
  14.             )
  15.         )
  16.         (princ)
  17.     )
  18. )
Since commands cannot contain points, radii such as 4.5 will be represented by the command "F4-5".
Lee
MSTG007
« Reply #8 on: July 21, 2015, 01:01:51 PM »
Wow lee once again... smooth and simple. Makes me wonder if that same format would work for an offset command. But way Cool.
Civil3D 2020
« Reply #9 on: July 21, 2015, 01:28:16 PM »
Thanks! - The OFFSET command could be something like:
  1. (   (lambda nil
  2.         (foreach dis '(4.5 10 20 30)
  3.             (eval
  4.                 (list 'defun
  5.                     (read (strcat "c:o" (vl-string-translate "." "-" (vl-princ-to-string dis)))) nil
  6.                     (list 'vl-cmdf "_.offset" dis)
  7.                    '(while (< 0 (getvar 'cmdactive)) (vl-cmdf "\\"))
  8.                    '(princ)
  9.                 )
  10.             )
  11.         )
  12.         (princ)
  13.     )
  14. )
The above will created commands "O4-5", "O10", "O20" etc.
MSTG007
« Reply #10 on: July 21, 2015, 03:16:39 PM »
hehehe... way awesome.
Civil3D 2020
bruno_vdh
« Reply #11 on: July 24, 2015, 06:42:16 AM »
Hello,
That's why I prefer to work with mapcar, the function list is returned to the loading
_$ (mapcar '(lambda (rad)
           (eval (list 'defun
                       nil
                       (list 'setvar "filletrad" rad)
                       (list 'setvar "filletrad" (getvar 'filletrad))
                       '(princ)
        '(4.5 10 20 30 40)
(C:F4-5 C:F10 C:F20 C:F30 C:F40)
_$
(Ps: fil is not essential  :-D)
Regards,
« Reply #12 on: July 24, 2015, 12:21:57 PM »
But what if the user changes the FILLETRAD system variable after the function has been defined?
The system variable will then be reset to the wrong value.
bruno_vdh
« Reply #13 on: July 24, 2015, 05:45:31 PM »
Yes sorry, I talk too fast and you are right. :oops:
Now I'll have a little cheat ..
(mapcar
  '(lambda (rad)
     (eval
       (list
'defun
'(/ *error*)
'(eval
   (list
    'defun
    '*error*
    '(msg)
    '(if msg (princ msg))
    '(princ)
'(*error* nil)
  '(4.5 10 20 30 40)
Regards,
