/// <summary>
/// Inserts a block into the specified Space.
/// </summary>
/// <param name="blockName">Name of the block to insert.</param>
/// <param name="insertionPoint">The insertion point of the block.</param>
/// <param name="database">The database to work in.</param>
/// <param name="space">The space to insert into</param>
/// <param name="attributes">The attributes to set on the block.</param>
/// <exception cref="System.ArgumentNullException">blockName;The block name cannot be empty</exception>
/// <exception cref="Autodesk.AutoCAD.Runtime.Exception">The database cannot be null.
/// or
/// The block does not exist in the current database.</exception>
/// <exception cref="Exception">
/// </exception>
public static void InsertBlock(string blockName, Point3d insertionPoint, Database database, Space space, Dictionary<string, string> attributes)
if (string.IsNullOrWhiteSpace(blockName))
throw new ArgumentNullException
("blockName",
"The block name cannot be empty"); }
if (database == null)
throw new Exception
(ErrorStatus
.NoDatabase,
"The database cannot be null."); }
using (var transaction = database.TransactionManager.TopTransaction)
if (transaction == null)
throw new Exception
(ErrorStatus
.NotTopTransaction); }
var blockTable = (BlockTable)database.BlockTableId.GetObject(OpenMode.ForRead);
if (!blockTable.Has(blockName))
throw new Exception
(ErrorStatus
.NotInDatabase,
"The block does not exist in the current database."); }
var blockDefinition = (BlockTableRecord)blockTable[blockName].GetObject(OpenMode.ForRead);
using (var blockReference
= new BlockReference
(insertionPoint, blockDefinition
.ObjectId)) {
try
BlockTableRecord currentSpace;
if (space == Space.ModelSpace)
currentSpace = (BlockTableRecord)blockTable[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForWrite);
else
currentSpace = (BlockTableRecord)blockTable[BlockTableRecord.PaperSpace].GetObject(OpenMode.ForWrite);
currentSpace.AppendEntity(blockReference);
transaction.AddNewlyCreatedDBObject(blockReference, true);
foreach (var objectId in blockDefinition)
var dbObject = objectId.GetObject(OpenMode.ForRead);
var attributeDefinition = dbObject as AttributeDefinition;
if ((attributeDefinition != null) && (!attributeDefinition.Constant))
if (attributes.ContainsKey(attributeDefinition.Tag))
using (var attributeReference
= new AttributeReference
try
attributeReference.SetAttributeFromBlock(attributeDefinition, blockReference.BlockTransform);
attributeReference.Position = attributeDefinition.Position.TransformBy(blockReference.BlockTransform);
attributeReference.TextString = attributes[attributeDefinition.Tag];
blockReference.AttributeCollection.AppendAttribute(attributeReference);
transaction.AddNewlyCreatedDBObject(attributeReference, true);
catch (Exception exception)
Log.Logger.Error(exception, "Unable to set attribute {Attribute} on block {blockName}", attributeDefinition.TextString, blockName);
Log.Logger.Error(exception, "Unable to insert the block {blockName} into the drawing {fileName}.", blockName, database.Filename);
throw new Exception
(ErrorStatus
.UnrecoverableErrors,
string.Format("Unable to insert block {0} into {1}.", blockName, database
.Filename), exception
.InnerException); }
