Author Topic: build a custom drawing search engine  (Read 2422 times)
Shay Gaghe
« on: July 20, 2015, 07:23:21 AM »
Hi
We spent hours locating drawing we need to reuse. I were thinking to set tags or keyword attached to the drawing the first time we create it, and then use a search mechanism to search for drawings by their tags.
The first attempt was windows 7 search,
I wrote  details in the tab :  A >  Drawing  Properties >Summery
Those details cannot be seemed in the Win 7 explorer. Where I can see them?
Second attempt  is by using design center:
1.   Opening a drawing
2.   Accessing Drawings Utilities > Custom
Tag - value
Scale – 1:20
Steel-T
Save them with the drawing.
Open design center , load the search utility , search for the costume tags that I initiate:
Scale – 1:20
Steel-T
The above yell no results
What im doing wrong?
Shay
Re: build a custom drawing search engine
« Reply #2 on: July 20, 2015, 08:58:16 AM »
I have never used the product but another solution.
http://www.ifiltershop.com/
huiz
  • Certified Prof C3D
« Reply #3 on: July 20, 2015, 09:11:37 AM »
And there is a Content Explorer available in AutoCAD as well.
http://blog.jtbworld.com/2011/04/autocad-content-explorer.html
« Reply #4 on: July 20, 2015, 10:44:05 AM »
WOW
That search function (doesn't function) in Design Center is like TOTAL crap!
How awesome.....if one tries to use it for what it theoretically is supposed to do, it's pretty much useless.
« Reply #5 on: July 20, 2015, 11:02:55 AM »
WOW
Hey MJ ... If you reboot it works  :P
« Reply #6 on: July 20, 2015, 11:22:23 AM »
WOW
Your sarcastic irony is deliciously funny.   :2funny:
Peter2
Peter
BricsCAD V23
