Author Topic: AutoCAD 2016 load *Cancel*  (Read 2288 times)
« on: July 19, 2015, 11:52:02 PM »
AutoCAD 2016
Vanilla profile .. as virgin as I can make it.
The initial load throws a *Cancel* on the command line some time after loading acad2016doc.lsp
I added a placeholder in the file to check.
Any subsequent  file open in the same session does not show the message.
Anyone come across this previously ??
ChrisCarlson
Re: AutoCAD 2016 load *Cancel*
« Reply #1 on: July 20, 2015, 11:33:32 AM »
Regenerating model.
AutoCAD menu utilities loaded.*Cancel*
Command:
Command:
Command:
Similar here
« Reply #2 on: July 20, 2015, 11:35:54 AM »
Regenerating model.
Command:
Command:
Command:
Similar here
Without meaning you any ill will;
I'm comforted by that ... misery loves company :)
Peter2
« Reply #3 on: July 20, 2015, 02:37:59 PM »
Confirmed for the German version too:
Regeneriert Modell.
AutoCAD Menü-Dienstprogramme geladen.*Abbruch*
Befehl:
Befehl:
Befehl:
I renamed also all "ApplicationPlugin"-Folder - same behaviour.
Peter
BricsCAD V23
