Author Topic: inserting blocks into existing drawings?  (Read 8721 times)
vinnyg
« on: July 17, 2015, 09:23:17 AM »
 :embarrassed2:
I have existing drawings with 3 or 4 paper space views. Whenever I try to insert additional blocks into new paper space views, nothing happens
I don't see any images at all. What's going on. Am using autocad 2014
tedg
Re: inserting blocks into existing drawings?
« Reply #1 on: July 17, 2015, 09:27:58 AM »
:embarrassed2:
When you say 3 or 4 paper space views, do you mean 3 or 4 layouts?
How are you inserting the blocks, using the -insert command?, copying from one layout and pasting into another?
Are they images or blocks?
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
tedg
« Reply #2 on: July 17, 2015, 09:32:18 AM »
Other information is probably needed, like are you inserting them through an active viewport and there may be a layer setting not allowing you to see them?
Are the blocks internal or from outside the drawing file?
Maybe you can explain your process in detail and maybe post a sample drawing file?
Rob...
« Reply #3 on: July 17, 2015, 09:42:34 AM »
It could be layers off or frozen.
Maybe the block is too big or a distance from the insertion point.
CAD Tech
« Reply #4 on: July 17, 2015, 10:09:48 AM »
:embarrassed2:
edit the block  BEDIT
verify
A) insertion point is 0,0
B) size/scale of the objects
Bad insertion points are far too common.
Things not draw appropriate for the scale they will be used at
C) annotative?
And was the proper ANNOSCALE assigned to the block(s)
« Reply #5 on: July 17, 2015, 10:15:41 AM »
also check layer frozen of off in viewport
and or locked globally
« Reply #6 on: July 17, 2015, 10:33:39 AM »
By paperspace views do you mean viewports? If so, and you're trying to create new block instances inside a viewport check the insertion point against the viewport's extents, being mindful of user coordinate systems and clipping planes etc. as well as layer and vplayer states relative to the active layer.
vinnyg
« Reply #7 on: July 17, 2015, 02:30:01 PM »
yes, viewports, trying to insert drawing or block from outside current drawing
vinnyg
« Reply #8 on: July 17, 2015, 02:31:29 PM »
:embarrassed2:
using insert command. blocks or drawings
vinnyg
« Reply #9 on: July 17, 2015, 02:33:00 PM »
checked for frozen layers
« Reply #10 on: July 17, 2015, 02:35:12 PM »
If you posted the drawing I bet this would get solved much quicker.
« Reply #11 on: July 17, 2015, 05:21:28 PM »
But it is so much more fun to let us wildly guess at what the problem is and offer solutions for everything that it might not be.
bluepencil
« Reply #12 on: November 10, 2015, 07:33:32 AM »
after inserting the block do
ZOOM EXTENTS...
and or select all...
it is either your block is too big, or very far out or it is very small...
hope this helps....
tedg
« Reply #13 on: November 10, 2015, 03:37:51 PM »
Or how about if you put a green frog on your monitor and tap your heels three times.. that may help too  :P
Krushert
  • FREE BEER Tomorrow!!
« Reply #14 on: November 10, 2015, 03:44:52 PM »
All the above steps are grossly complicated.
Do the following at the command line
Type EXPLODE and then type ALL when it ask for you to select objects.   Repeat as necessary.
 :tongue2: :-P :evil: :crazy2: :gum:
How many emojis do i have to enter so you know I am being a wise petunia?  Seriously don't listen to what I speak of.  If is not for the faint of heart.
