hi
simple code to get an array of points. i tried using macpar,lambda and others....but coudnt make it work.
is this the only way to achieve the task?
(defun getPolarCoors(stp int / lst )
(setq x 0)
(repeat 4
(setq lst (cons (polar stp 0.0 (setq x (+ x int)) )lst))
