Author Topic: distribute point along a defined range in a curve  (Read 1458 times)
Shay Gaghe
« on: July 12, 2015, 07:23:49 AM »
I wrote a code to distribute point  along a defined range in a curve. i want the points to be distributed evenly.
i tried to divide the distance between the start and end parameters by 90% percent of it,
i did it because i wanted my routine to be scalable and fit all curve lengths.
points are not evenly distributed and go beyond the end parameter.
cant figur out what is going wrong.
(defun destribute (obj strPrm endPrm  /  d w ppt ppts d pv x)
  (setvar "osmode" 2048)
  (if (setq obj (vlax-ename->vla-object obj))
      (setq d (vlax-curve-getDistAtParam obj strPrm)                         ;_get the distance from curv start to strPrm
    w (- (vlax-curve-getDistAtParam obj endPrm) d)                   ;_get the distance from strPrm to endPrm
    x (/ w (/ (* w 90)100)))                                         ;_divide w by 90 % of it
      (setq pv strPrm)
     (while (< pv endPrm)                                            ;_while pv is smaller than endPrm
       (setq pv (vlax-curve-getParamAtDist obj d))                   ;_get the parameter point  at d
       (setq d (+ d x))                                              ;_add pv to list
       (setq ppts (cons (vlax-curve-getPointAtParam obj pv) ppts))   ;_walk d x units as d
  ppts
please help
S
kpblc
Re: distribute point along a defined range in a curve
« Reply #1 on: July 12, 2015, 09:30:27 AM »
Perhaps the reason is
  1. _$ (setq value 12)
  2. 12
  3. _$ (/ (* value 90) 100)
  4. 10
  5. _$ (/ (* value 90.) 100)
  6. 10.8
Sorry for my English.
hmspe
« Reply #2 on: July 12, 2015, 10:29:46 AM »
Are the values for strPrm and endPrm really parameters?  See http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/what-is-a-the-parameter-of-a-curve/td-p/896825 and http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/vlax-curve-getparam-functions-what-are-they/td-p/789993
If you are using points to specify the ends of the range you want points in I would do something like this
(defun distribute (object start_point end_point point_count / point_list start_param
                   end_param temp start_dist span interval counter points)
  (if (vle-enamep object)
    (setq object (vlax-ename->vla-object object))
  (if object
      (setq point_list (list
                         (vlax-curve-getStartPoint object)
                         (vlax-curve-getEndPoint object)
      (if (equal start_point (car point_list) 1E-5)
        (setq start_param (vlax-curve-getStartParam object))
        (if (equal start_point (cadr point_list) 1E-5)
          (setq start_param (vlax-curve-getEndParam object))
          (setq start_param (vlax-curve-getParamAtPoint
                              object
                                (vlax-curve-getClosestPointTo object start_point)
      (if (equal end_point (car point_list) 1E-5)
        (setq end_param (vlax-curve-getStartParam object))
        (if (equal end_point (cadr point_list) 1E-5)
          (setq end_param (vlax-curve-getEndParam object))
          (setq end_param (vlax-curve-getParamAtPoint
                              object
                                (vlax-curve-getClosestPointTo object end_point)
      (if (and start_param
               end_param
        (if (> start_param end_param)
          (setq temp        end_param
                end_param   start_param
                start_param temp
      (setq start_dist (vlax-curve-getDistAtParam object start_param)
            span       (- (vlax-curve-getDistAtParam object end_param)
                          start_dist
            interval   (/ span (1- point_count))
      (setq counter 0)
      (while (< counter point_count)
        (setq temp   (vlax-curve-getParamAtDist object (+ start_dist (* interval counter)))
              points (cons (vlax-curve-getPointAtParam object temp) points)
        (setq counter (1+ counter))
      (setq points (reverse points))
  points
(defun c:test ( / object start_param end_param span point1 point2)
  (setq object      (car (entsel "\nSelect object: "))
        span        (vlax-curve-getDistAtParam object end_param)
        point1      (vlax-curve-getPointAtDist object (/ span 3.0))
        point2      (vlax-curve-getPointAtDist object (* (/ span 3.0) 2.0))
  (distribute object point1 point2 7)
"Science is the belief in the ignorance of experts." - Richard Feynman
roy_043
  • BricsCAD 18
« Reply #3 on: July 13, 2015, 04:04:36 AM »
@ Shay:
I think there are two issues:
1.
The test expression of the while loop tests the *old* value of pv.
This can easily be fixed:
Change this:
  (setq pv (vlax-curve-getparamatdist obj d))
To this:
(while (< (setq pv (vlax-curve-getparamatdist obj d)) endPrm)
2.
The point are evenly distributed *along* the curve. So to check the output you should not measure the linear distance from point to point.
