Author Topic: (C3D 2015) Match line station not visible in viewport  (Read 4918 times)
« on: July 10, 2015, 11:05:23 AM »
I finally got around to using view frames and creating sheets in C3D but my match line stations are not visible when i go to my sheets. I can see them in model space just not in the viewport on the layout. I check all the obvious things.
What i did;
create view frames along my alignment (17)
created sheets (separate dwgs) using a page setup in a template.
Matt__W
  • I like my water diluted.
Re: (C3D 2015) Match line station not visible in viewport
« Reply #1 on: July 10, 2015, 11:14:42 AM »
Sounds like an annotation scale issue.
Autodesk Expert Elite
« Reply #2 on: July 10, 2015, 11:22:13 AM »
Not annotation scale.
If I slide the viewport over i can see the right matchline station. *shrug*
« Reply #3 on: July 10, 2015, 12:00:02 PM »
change your style
Match Line Style that is.... ;-)
« Reply #4 on: July 10, 2015, 12:08:35 PM »
change your style
will look again!
thanks.
« Reply #5 on: July 10, 2015, 12:35:31 PM »
let me be more specific...Match Line Label Style
place them to the 'inside' of the sheet than they will be visible, or you may need to change (recalculate) the size of your plan view window(s)
« Reply #6 on: July 10, 2015, 01:10:19 PM »
Thanks but I still don't see why they are not displaying. I see nothing about 'inside' in the style either.
« Reply #7 on: July 10, 2015, 01:19:49 PM »
Here are the drawings i'm working on.
« Last Edit: July 10, 2015, 02:38:57 PM by Mark »
BlackBox
« Reply #8 on: July 10, 2015, 01:47:59 PM »
In Temp-MACDILL.dwg, select a Matchline, and modify the Left and Right Label Styles.
Specifically, Create/Edit, Layout tab - change both Label Styles to be set Top Center, with a Y Offset of -0.05.  :-)
« Reply #9 on: July 10, 2015, 01:51:37 PM »
offset the text to inside of the match line...-y typical as noted above
« Reply #10 on: July 10, 2015, 02:32:00 PM »
Holy cow! You have got to be kidding me. That makes no sense what-so-ever.
Thanks guys, that worked!
« Reply #11 on: July 10, 2015, 02:38:41 PM »
Behold the source of MY crazy!
BlackBox
« Reply #12 on: July 10, 2015, 03:59:23 PM »
Happy to help, Mark :-)
Given the behavior of the labels, I'd speculate that the use of Left and Right, is describing which side of the 'sheet' it appears on, and not what side of the matchline it resides. *shrugs*
« Reply #13 on: July 10, 2015, 05:38:07 PM »
I typically 'flop' them and use left on the right side and right on the left side.
