Author Topic: Working with registry in different languages  (Read 2988 times)
Peter2
« on: July 08, 2015, 06:12:48 AM »
Modifying the registry (e.g. for Profiles) has the challenge of different languages. Here is a value from my German AutoCAD - you see the mixture of English and German:
  1. Windows Registry Editor Version 5.00
  2.
  3. [HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B001:407\Profiles\Peter\Dialogs\Datei wählen]
  4. "PreviewVisible"=dword:00000001
  5.
Who has experience in this topic? How to handle the different keys in different languages? Is it possible to use only English and it will work in all other languages? Or not?
Peter
BricsCAD V23
kpblc
Re: Working with registry in different languages
« Reply #1 on: July 08, 2015, 07:05:10 AM »
use (vlax-product-key) function to get "Software\Autodesk\AutoCAD\RXX.X\ACAD-YYYY:ZZZ" value
Sorry for my English.
Peter2
« Reply #2 on: July 08, 2015, 08:54:07 AM »
But how this will help if I have
- "Datei wählen" in German
- "Select file" (File select?) in English
- "Selectionez fichier" in French?
Peter
BricsCAD V23
ChrisCarlson
« Reply #3 on: July 08, 2015, 09:00:04 AM »
So you want prompts based on local language?
ChrisCarlson
« Reply #4 on: July 08, 2015, 09:03:57 AM »
You could incorporate Google Translate and send each prompt into the translator as English and print with the translation?
kpblc
« Reply #5 on: July 08, 2015, 09:43:12 AM »
It seems very strange. I use two localizes: russian and english. Dialogs subhives have same names - LayerManager, DrawingSettingsDialog and so on. Because of this (i hope) all you have to do is to get correct registry hive and profile name.
Peter2
« Reply #6 on: July 08, 2015, 09:47:01 AM »
The registry-key I posted above is ...
a) a current "project" to set the preview-window in file-open-dialogue
(If there is an existing solution - hints are welcome).
b) a good example for the problem.
"How to create a Lisp which ...
a) switch the key "PreviewVisible" between 0 and 1
b) works in current AutoCAD-version (2012 - 2016)
c) and in "all" languages?
to a) Simple vl-registry-write. No problem.
to b) I have to loop through versions and profiles and ....
That should be no problem; snippets are here in the Swamp
to c) How to know / to find / to select language-dependent keys like "Datei wählen"? To solve it for one language is clear, but how to solve it for "all" languages?
...Dialogs subhives have same names - ....
Really every key? I have a few keys (see above) which are in German; the greatest part is in English.
Peter
BricsCAD V23
« Reply #7 on: July 08, 2015, 10:24:22 AM »
How about using
  1. (setenv "PreviewVisible" "0")
Peter2
« Reply #8 on: July 08, 2015, 01:28:52 PM »
How about using
Thanks. Sounds great and can be set, but ...
a) it has no effects. Neither after restart of AutoCAD.
b) the second question (language depending keys) is still unsolved.
Peter
BricsCAD V23
« Reply #9 on: July 08, 2015, 01:55:51 PM »
If you're only dealing with 3 languages, why not just use a conditional statement using (getvar 'locale) ?
  1. (strcat "HKEY_CURRENT_USER\\"
  2.         (vlax-product-key)
  3.         "\\Profiles\\"
  4.         (getvar 'cprofile)
  5.         "\\Dialogs\\"
  6.         (cond ((= "ENU" (getvar 'locale)) "Select File")
  7.               ((= "DE" (getvar 'locale)) "Datei wählen")
  8.               ((= "FR" (getvar 'locale)) "Selectionez fichier")
  9.               ("")
  10.         )
  11. )
« Last Edit: July 08, 2015, 02:14:36 PM by ronjonp »
roy_043
  • BricsCAD 18
« Reply #10 on: July 09, 2015, 04:30:41 AM »
How about using
For BricsCAD I have found that changing BricsCAD registry settings during a CAD session is not effective. The program reads settings at startup, and it is obviously 'aware' of changes made using setvar etc. But it does not reread the registry during a CAD session. And when the program closes it writes the settings it has stored back to the registry. This means, indeed, that registry changes made through Lisp do not have any effect and are lost when the program closes.
